Way Motor Works just got a new batch of our famous WMW wheel spacers in. If you've been looking for spacers for your MINI here you go. Our wheel spacers are made from lightweight aluminum, and have multiple holes in them to save weight and make lining them up easier. Then the center bore that mounts on the hub is angle cut to keep it from sticking, but even better there is a groove on the backside too keep it from corroding to the hub for easy removal. All of our spacers are also Hub Centric so they are a perfect fit. 5mm or our 15mm and 20mm
