WOLO Bad Boy 419 Horn
Discussion in 'MINI' started by SNEEEZY - Erika, Oct 19, 2010.
  1. SNEEEZY - Erika
    1,212
    116
    Female
    I purchased this horn because it's LOUD.
    Not quite sure how/where to install it on my R50 Justa.
    I'm hoping that someone has installed this in their 1st Gen. MINI and would be willing to:
    a. Give me some tips/tricks/guidance.
    b. Take a pic of where it's mounted.
    Thanks in advance!
    This horn will hold me over until I acquire a used set of semi-truck or train horns. :devil:
  2. thirdraildesignlab
    thirdraildesignlab New Member
    Sep 21, 2010
    102
    architect
    SF Bay Area
    no clue over here, but I'll be watching this thread to see what comes of it. I'm a fan of a good horn.
  3. beken
    beken Well-Known Member
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
    a friend of mine (more than 20 years ago) had an air horn mounted inside his front bumper in his Honda Civic (when bumpers were made of metal). His was loud. The only problem was it took maybe a 1/2 second for the compressor to spool up and make any noise come out of the horns. That was awhile ago and I've wanted to get one myself. Thanks for showing this and I too would be interested to see how yours works out and when you mount it. I would recommend mounting it as close to the front and pointed downward a bit (so water won't run into the horn.
  4. CHKMINI
    I mounted electric/air horns under the hood of my '04 MCS. I sold the car and don't have pictures but we mounted the horns on the firewall on the RH side. We wired the horns by tapping into the OEM horn wire so that the horns operated with the OEM horn button. We tried to find room up front, behind the bumper, in the inner fender and the firewall was the only spot for fitment.
  5. MiniKar
    MiniKar Member
    Sep 24, 2010
    62
    Nevada
    Can you post a photo of these horns ?
    I need to see just how large it is . . . . . . . .
