Engine Drivetrain 1st Gen Cooper S WOT and Code P0108
Discussion in 'Tuning and Performance' started by GeorgeCo, Nov 27, 2012.
  1. GeorgeCo
    GeorgeCo Site Sponsor
    Motoring Alliance Sponsor Supporting Member
    Oct 29, 2009
    253
    38
    Motorer
    Mt. Airy, MD
    Thought I'd pick the brain of the MA collective: Two weeks ago I spent a couple of days on the track at Summit Point, WV. The main circuit has a 2,900 foot straight that's spent mostly at wide open throttle. After a couple of hard laps I'd get a CEL with code P0108 which is MAP sensor. I'm running a stock R53 head and injectors with a 15% reduction pulley, Alta intake, and custom tune. If it's like my old car before I upgraded to larger capacity injectors, it's probably starting to lean out when the injectors are run at or near capacity. I don't have an A/F sensor. But does that sound like a likely cause of the code? I tried testing the theory by clearing the code and running a session at a slower top speed (video), then went back to full speed the next session and threw the code again. Thoughts?
  2. k-huevo
    k-huevo Club Coordinator
    159
    Pipe Creek, Texas
    That's a T-MAP code generated in the intake manifold. Could be a faulty sensor, tune related, or obstruction. It is not a lean condition.
  3. Dave.0
    What size "larger injectors" do you have and who did your custom tune?
    If your injectors are not scaled correctly this can happen. I would contact your tuner because they should be able to make the needed adjustments to correct this problem.
    You could also pull your Map and T-Map sensors and clean them because they could be faulty or have some oil build up on them if they have never been cleaned or replaced.
  4. Jason Montague
    :cornut: When my Margi(08 R56 MCS/JCWm..........yeah turbo and not S.C. but keep reading please) was throwing that code regularly after rapid decceleration from high speed, the culpret was found to be the 'old silicone Alta intake hose' collapsing as it was not reenforced. Trashed the silicone Alta intake hose(which they don't sell any more) and got the Alta metal intake pipe. NO PROBLEMS SINCE. Is the intake hose no longer round but starting to collapse? Even with the S.C. R53 vs the Turbo R56, that 'Alta Intake' caught my eye. Hope this helps.:Thumbsup:
  5. Dave.0
    ^^^^ very good point.
    Alta it almost fits and works.
  6. GeorgeCo
    Oct 29, 2009
    253
    38
    Motorer
    Mt. Airy, MD
    Hmmm. Interesting comments so far. On my previous R53 we put on the JCW 380cc injectors. All of the other mods are the same for this car.
    Jason: The Alta tube that collapsed, was it this one or an earlier model? This is the one I have. I'll have to get in and take a look to see if it's still rigid.
    I've got some MAF sensor spray cleaner coming in the mail. I'll try cleaning off the sensor, but hard to test if not on the track. :biggrin5:
  7. KittyMini
    KittyMini Club Coordinator
    1,183
    The R53 does not have a MAF sensor.
  8. Jason Montague
    :cornut: Yes Sir, that's the one. Of course Margi's was a slightly different shape being for the R56 Turbo.:cornut:
  9. BlimeyCabrio
    I've had no prob with Alta silicone intake hose for 100k miles. Zero.
  10. Nathan
    P0108 is the following:
    Manifold Absolute Pressure/Barometric Pressure Circuit High Input
    Having seen this code myself more than once it has been my experience that the MAP sensor on the front of the engine is going bad. At least in my case that has been the solution twice now. The MINI Part # is 12-14-0-872-648.
    Last time I had one go south was at MOTD in 2012. Hendrick MINI saved my butt by bringing a part up from the dealership. Much to their credit they allowed me to install the part and test to validate the issue was resolved before I paid for the part.
  11. BlwnAway
    BlwnAway Well-Known Member
    Nov 24, 2011
    474
    290
    #11 BlwnAway, Nov 28, 2012
    +1, you may be able to clean it & make it last a little longer, but you're prob. just getting lucky here and getting an early warning that it's going bad.
    Or (just a wild stab here)
    Did you by any chance notice the boost level? A blockage in the CAT can sometimes give you an abnormally high boost level, esp. at WOT, and this could be causing the sensor to " sit up and take notice".
  12. GeorgeCo
    Oct 29, 2009
    253
    38
    Motorer
    Mt. Airy, MD
    Roger. Using MAF sensor spray to clean the MAP sensor. Unless there's something better to use....
  13. GeorgeCo
    Oct 29, 2009
    253
    38
    Motorer
    Mt. Airy, MD
    Hadn't thought of that. I did notice boost was fairly high at times. I put that down to the cool weather. The photo below shows a comparison of a couple of different laps from different sessions. On the left, boost was up above 15 lbs. I threw a code in this session. On the right, boost was only up to 13 or so. No code. Related or coinkydink?
  14. Norm03s
    Norm03s New Member
    534
    Working at being retired.
    Somewhere in Sykesville. Md.
    #14 Norm03s, Nov 28, 2012
    This happened to me also, sensor going bad. Replaced it, resolved problem a couple years ago. I run a 17% pulley.
  15. BlwnAway
    Nov 24, 2011
    474
    290
    Not, with those levels no, prob. the sensor.
