2006 Mini S - what to look for
Discussion in 'Starting Line - New Member Introductions' started by Zappin1, Nov 13, 2015.
  1. Zappin1
    Zappin1 New Member
    Nov 13, 2015
    Hello, we are looking at a 2006 Mini Cooper S with 68,000 miles for our 20 year old son. He is paying for it and we were wondering if there is anything we should ask or look for or be aware (scared) of. There is no dealer in the area but do have experience with a local import shop who says they can work on Minis. We just don't want him to get into something that will dollar him to death in repairs. Thanks for any info you can provide.
    6,176
    Welcome to MA!
    I would ask if the front control arm bushings have been replaced, they go bad around 35,000miles. I would replace them with power flex bushings they will last the life of the car. Also make sure it has had regular oil changes. The radiator and brake fluid should be changed every 2 years like on any car. Ask if they will let you take and have a pre-buy done on it. If they say no that may tell you some thing.
    What part of the country do you live it? One of our members may be able to point you to a good shop
  3. Zappin1
    Zappin1 New Member
    Nov 13, 2015
    Thanks for the info. We are in Billings, Mt. Dana Motors here was the Saab dealer and while Saab went Tango Umbrella, they still work on imports. According to the husband, his wife was meticulous about the car and has had regular oil changes and they have never had any mechanical issues (so they say). Replaced brake pads recently (have receipts) and have two sets of wheels with Bridgestone winter tires and Eagles for summer. Both with less than 6000 miles (receipts also).
  4. Goldsmithy
    Jan 30, 2015
    1,748
    982
    TCB
    Main Street in the land of Oz
    Any other receipts...especially for oil changes and/or coolant problems? Might not be a bad idea to check for stored codes.
    A PPI is definitely need for ANY MINI...without a warranty.
  5. wmwny
    4,036
    2,236
    Welcome to M/A! :Thumbsup: With your selected tires, it would appear you will survive the weather in Montana just fine!
  6. Nathan
  7. Zappin1
    Zappin1 New Member
    Nov 13, 2015
    Thanks for the VIN check, I think they had most of it listed but good to see the information verified.
  8. Canusrufis
    Canusrufis RMW Powered R53
    208
    103
    Winston Salem NC
    That looks like a well taken care of MCS. Interior says a lot IMO. Still its around the mileage maintenance will need to be considered - broken or not. MCS02 mentioned the main suspension consideration but all the ball joints need to be looked over. The steering shouldn't have slop in it. Also has the power steering pump been replaced? Are the hoses connected to the PS reservoir leaking (or show signs of leaking)? Other than that, and outside a "pre-buy" inspection, just getting under the car and looking for fluid leaks and rust (mostly on the exhaust/mufflers.
    And get him a bentley manual! http://www.amazon.com/MINI-Cooper-Service-Manual-Convertible/dp/0837616395
  9. Nathan
    It's an 06 so in theory the power steering pump is fine being it is not covered in MINIs recall.
    BTW, 06 is the bestest year for an R53
  10. Canusrufis
    208
    103
    Winston Salem NC
    I've MCS 05, not covered under warranty (or deemed "resolved" by MINI) and it still failed. The question was whether or not it had been replaced. Those things are not cheap.
  11. Zappin1
    Zappin1 New Member
    Nov 13, 2015
    Thanks all, we will be sure and check it out.
  12. fishmonger
    fishmonger Well-Known Member
    May 13, 2015
    984
    769
    Madison, WI
    [ame="https://www.youtube.com/watch?v=QUhzyfb3cxg"]Buying a used 2002-2006 MINI Cooper - what to look for mechanically - YouTube[/ame]
  13. MCS02
    6,176
    Thats a good video. That may make a good sticky so new members could find it fast.
