2007 MINI MCS
Discussion in 'Member Garages' started by oldbrokenwind, Oct 18, 2012.
  1. oldbrokenwind
    oldbrokenwind Active Member
    Oct 18, 2012
    196
    107
    Northern NV
    2007 MINI MCS (2012-10-18 15:24:49)
  2. oldbrokenwind
    Oct 18, 2012
    196
    107
    Northern NV
    #2 oldbrokenwind, Nov 10, 2012
    Here's a "journal" of my upgrade installations. It gets updated as I add new stuff. Updates will not significantly change earlier entries.
  3. HurricaneDave
    HurricaneDave New Member
    Apr 9, 2012
    99
    34
    Tellecommunications Engineer
    Ball Ground, GA
    Very nice write up!!
  4. Jason Montague
    :cornut: Love the Confederate Grey:Thumbsup: and the add on gauges. From the write up, lot a work in that MINI. See a lot of R53s in the rear view, do ya?:lol::ihih::Thumbsup:
  5. oldbrokenwind
    Oct 18, 2012
    196
    107
    Northern NV
  6. Nathan
    Garage of the Day 9/10/13
  7. oldbrokenwind
    Oct 18, 2012
    196
    107
    Northern NV
    Been awhile since my last update. As before, only the last couple pages are new, no changes to earlier versions.
  8. oldbrokenwind
    Oct 18, 2012
    196
    107
    Northern NV
    Here's my latest update, only the last page or two is new. Also have my last dyno runs. Next dyno should be 300+ WHP and torque, with 30PSI boost.
  9. oldbrokenwind
    Oct 18, 2012
    196
    107
    Northern NV
    Here's another Journal update, with my latest dyno chart. Note that the chart doesn't include boost. It was set to and made 30 PSI.
  10. oldbrokenwind
    Oct 18, 2012
    196
    107
    Northern NV
    Been a year since my last update. Still getting used to the big power. Finally decided to bite the bullet and talk seriously about a Manic tune. Seems they can use my AP tune as a "base" tune, plus tune for 30PSI without using a fuel (or boost) cut defender, and maybe even get rid of conditions causing my troublesome P2884 / P2885 codes.
    Since we have family in the Phoenix area, we decided to work with EuroTechs for a couple days. This dyno chart is my first one with Manic and isn't done with the correct WMI mix --- the mix is changing from 50 - 50 to 80 - 20 for the "daily driving" map, so I need to use up the existing mix. There was some "fine tuning" done after this chart, so there might be even more WHP available. I'm hoping to get another dyno run at ThunderHill mid-Feb, if I can keep it together 'til then.
    FYI --- it's a stage 4 tune with my original custom AP map as the "base". Map A is for use without WMI, map B is for daily driving with 80 - 20 WMI, and map C is for 100% meth --- when I need an adrenalin rush!
    As with past journal versions, this one doesn't change older info, just adds a new page or two.
  11. 00Mini
    2,058
    Nice looking second generation S with a ton of power making mods !!
  12. oldbrokenwind
    Oct 18, 2012
    196
    107
    Northern NV
    Had a hell of a time finding this thread --- forum admin must have changed the "garage" structure, 'cause I couldn't get here from my "user CP" garage link.
    Anyhow, here's my next update --- same process as before --- only the last page or two is new.
  13. 00Mini
    2,058
    Good luck with your rebuild !!
  14. MCS02
    6,176
    I think it's new name should be OverBoost. :D
  15. oldbrokenwind
    Oct 18, 2012
    196
    107
    Northern NV
    One more update, possibly the last for this thread. It's only a couple new paragraphs, with no changes to earlier content.
    The saga continues here http://www.motoringalliance.com/forums/373501-post1.html, describing how I broke it, then that one moves on to a third one describing a rebuild.
  16. Firebro17
    A true "sleeper." You'd never know it at first glance.
  17. MCS02
    6,176
    Nice Gen2!
  18. Sully
    Sully Administrator
    Jul 21, 2015
    2,097
    912
    Software
    30350
    Agreed... and built.. :Stig:
