2nd Gen R56 Cooper Headlights
Discussion in '2nd Generation: 2007+ R55 through R61' started by d0r33t0s, Jul 11, 2015.
  1. Grizld700
    Grizld700 Well-Known Member
    Feb 2, 2016
    1,212
    47
    Eastern Iowa
    Hmmm. I'll have to see if anyone has done this before and they have a cut off...
  2. Goldsmithy
    Jan 30, 2015
    1,748
    982
    TCB
    Main Street in the land of Oz
    Are headlights adjustable? I would like mine to shoot out just a "little" more. Is it complicated? For an idiot....
  3. TheModFather
    I'll take some pictures of the adjustment screws when I get home Goldsmithy... It's easy, but without a cable adjuster there is a lot of opening and closing the hood involved... (R50/52/53 only, R56 and R60 variants with fixed lights are much easier. )
  4. Dave.0
    The best place for you to look is the fourm below. They have all the info you would every need but you need to search and do a lot of reading.
    I was going to change my OEM housing with parts from the retrofit source but the cost and effort was not worth it in the end.
    Forum - HiDplanet : The Official Automotive Lighting Forum
  5. TheModFather
    ^^^^ Yep! Find a set of OEM Xenon's from a part out, and have somebody code them in to work.
    Goldsmithy, if you have the standard halogen lights here's your adjustment screws...
    The Up/Down is the inboard screw ( 90% maybe 40~60% sure on that)
    The Left/Right adjustment is the outboard screw...
    If you have the Xenon's I don't remember if the adjusters are the same, I haven't had those since 2009... Paul could probably tell you though.
  6. Dave.0
    The HID / Xeons have the exact same adjustment screws for the HID housing.
  7. Goldsmithy
    Jan 30, 2015
    1,748
    982
    TCB
    Thanks, Dick:Thumbsup:
  8. Savvy
    #48 Savvy, Feb 17, 2016
    Dick's dorked memory bank is spot on for which screw does what. I just had to adjust my right headlight last week. The Bentley manual shows it very well too.
    If you don't have a garage ceiling to work off of to make the adjustments... I like finding a 7-Eleven, or similar convenience store with a brick exterior and a level parking spot to use as a guide for alignment. Granted it can be tough to find one with a level parking spot that matches the level lines of the brick... but it works in a pinch.
  9. Grizld700
    Feb 2, 2016
    1,212
    47
    Eastern Iowa
    I have a TON of reading to do. I may have to learn up on NCS-Expert and learn to code myself. Nobody around my area specializes in MINIs that deep.
  10. 00Mini
    2,062
    To me that's a serious commitment and to be commended !! :Thumbsup:
