Where can I get 4 10-12mm wheel spacers that are hub centric. Not the universal one size fits all garbage? Lucky for me the TSW studs are more than long enough
Turner Motorsport here: Turner Motorsport: Search H&R are the only ones I've found that are quality hub centric. Using the 5mm to clear the AP kit.
I guess the edit function is broke I noticed you said 10mm, not sure about those. H&R has everything else. Good luck.
Yea. I think I found a place to make me a set. Id really need a set of 4 in 12mm with a 56.1 bore. I dont think the 10mm is going to clear. I had to use 2 cheap'o 1/4" spacers to clear the brakes (just to test not to run ). 1/2 is = to 12.7mm .
How soon do you need these? I'm looking into machining some for myself, would be willing to share. I would need a few weeks to iron out all the details. Material, programming, time, cost, finish, lots o ironing. Bryan ...I'm guessing you can wait on these.....haha. Let me know.
Thanks guys. Looks like I will have lots of options. I have email about 5 places. They should reply on Monday so I will report my findings.
What wheels are they for? If the wheels are OEM (or hubcentric for MINI), 10mm is an awkward spacer size. Too thick for the spacer to be just a flat disc (hub won't stick through far enough to center the wheel) but if the spacer has its own centering flange, it will have very thin metal underneath to support it. That's why the H&R spacers jump from 5mm to 15mm with no sizes in between. However if the wheel is aftermarket and uses a centering ring, the centering ring can be integrated into the spacer and would make it structurally sound.
Wheel Adapters, Wheel Spacers, Hub Rings, and much more! | Motorsport Technology <- that place can make any hubcentric spacer or lug adapter. i dunno if your asking for it but if your looking for an "odd-ball" size then these guys can make it
