Brakes Wheels 2nd Gen Tires 14 to 12mm Stud Conversion HELP
Discussion in '2nd Generation: 2007+ R55 through R61' started by Redbeard, Jan 5, 2011.
  1. Bigprfed22
    Bigprfed22 New Member
    Dec 1, 2010
    95
    VA
    Experience works wonders....
    whos guilty?
    <-----------------this guy
  2. Redbeard
    1,636
    398
    Glorified spreadsheet jockey.
    Well the studs are in have almost a week of DD and a trackday at Streets of Willow on them. Holding just fine.
    I checked the torque after the wheels cooled after each run session. There was a smidge of tightening that needed to be done due to some stud stretch after the first two sessions but after that they stayed solid @ 83 ft/lbs (Been told amounts from 80-85 so I split the difference). Swapped back to street tires and rims and I have been happy.
    Good stuff! :Thumbsup:
  3. Metalman
    7,689
    Ok.....
    Help me here....
    What are the benefits of wheel studs over wheel bolts?
  4. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    opens up more wheel options. I recall sending a very cool set of 5Zigen wheels back because the tire shop didn't think to offer them (the MINI OEM bolts were too big) :mad2:
  5. Metalman
    7,689
    Thanks...
    Makes sense now.
    Couldn't understand why going to a smaller stud was a benefit.
  6. Redbeard
    1,636
    398
    In my case: I got a set of 17"/17 lb wheels but the acorn seat was too narrow for the lug bolts to seat. So a swap to 12mm studs enable me to use lug nuts that have a narrower acorn seat.
    Had I gotten a set of rims that had a better fitting acorn seat I wouldn't have bothered with the swap to studs. However, I got those rims with new tires on them for $300. Kinda hard to say no to that. :D
    There is no decernable performance advantage. Some guys/gals find them easier for swapping wheels (AutoXes and track events). It does allow for a wider selection of aftermarket wheels on the later generation MINIs as well.
    When you are swapping wheels at a prodigious rate it is a heck of lot easier to hang them on the studs than line up those bolts.
    Plus you can use these really lightweight tapered seat lug nuts.
  8. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    I run wheel spacers and there were no black 14x1.25 longer than stock lug bolts available so I switched to studs.
  9. ScottinBend
    I have it on a very good authority that someone, who was not a friend of the driver :D, actually backed off the lugs just before. The wheels came off way to early just due to them being lose.
