15 X 8s for an R53? for track duty
Discussion in 'Track Days & HPDE's' started by mini_racer, Dec 27, 2010.
  1. broadwayline
    broadwayline New Member
    May 5, 2010
    6
    Are you guys able to fit the R56 (JCW) calipers under the 15" 949 wheels?
  2. jasonsmf
    jasonsmf Active Member
    111
    27
    engineer
    Elyria, Ohio
    I tested my 15x8's on a 07 R56 S: The wheel appeared to fit although you would need to open up the lug holes for the 14mm lug bolts if that's what you run.
  3. mini_racer
    mini_racer Well-Known Member
    Engr Manager
    I would bet $$$ that there is no way this would fit!
  4. jasonsmf
    111
    27
    engineer
    Elyria, Ohio
    Wait a minute...maybe I answered incorrectly....are we talking R56 S (same as R53 JCW) brakes or are we talking R56 S JCW here?
  5. broadwayline
    May 5, 2010
    6
    I was referring to R65 S brakes on a R53 (same as R53 JCW kit)
    15" hollies are already really close to my standard R53 brakes but I am looking to go to something larger yet OEM for time attack, was there much clearance if any when you tested the 949 15"s on the R56S?
  6. jasonsmf
    111
    27
    engineer
    Elyria, Ohio
    In that case...yes, they will fit, much more clearance than holies. It's been a few years, but from what I remember, there seemed to be a safe amount of caliper clearance to the R56S calipers. You might need a low profile wheel weight, but to be honest, I can't remember exactly.
  7. howsoonisnow1985
    howsoonisnow1985 New Member
    Aug 8, 2009
    171
    Inmate
    Santa Cruz County Jail
    Shee's this is the best thread ever!!
    All the questions I had are here. Guess, it the nearly same situ for Enkie PF01s 15x8 and 35 offset.
  8. KC Jr 54
    KC Jr 54 New Member
    Jun 3, 2009
    402
    20
    Machine Operator
    Tyler, TX
    Just throwing these out there:
    R56 front rotors:
    15x8 et36 6uls, NO spacer. The fit is perfect IMO.
  9. mini_racer
    Engr Manager
    #29 mini_racer, Mar 5, 2011
    Those wheels look very familiar....... :^)
    RR wheel, it definitely pokes a little more than the front due to the 5mm spacer required to clear the trailing arm. Ok, actually I maybe could have gotten away with a 3mm.
    Trying to show the spacer installed in this second pic.
    And this third pic is of the RF obviously.
    Trying the new Tapatalk features in uploading pics from the photo album, hope it works. [​IMG] [​IMG] [​IMG]
  10. mini_racer
    Engr Manager
    #30 mini_racer, Mar 5, 2011
    multi post delete
    Well since I own this post anyway............
    Hmm, it looks like the new Tapatalk advanced feature works, even though it gives you are error.
    My car is lowered about 0.75", so these smaller diameter wheels definitely have some wheel gap, but for track purposes, they are perfect, at least for me.
    The rears with 5mm spacers required some longer lug bolts, but moving forward I will get studs.
  11. howsoonisnow1985
    Aug 8, 2009
    171
    Inmate
    Schweeeet!!:Thumbsup:
    I love you'se wheels guys!!
    I just found some on craigslist what does 1st gen mean in terms of referencing 949 6ULs? What are the differences between 1st and 2nd gen wheels? They are black centers with machined lips.
  12. mini_racer
    Engr Manager
    Go here for the details, and thanks, they are awesome wheels. The 15 X 8s weigh 12.3lbs, just crazy light weight.
    http://949racing.com/wheeltech.aspx
  13. jasonsmf
    111
    27
    engineer
    Elyria, Ohio
    The first gen 6UL's were gravity cast; the second gen 6UL's are low pressure cast (better) and are of a better grade aluminum. Additionally, the second gen wheels are made with larger radii on the spokes, theoretically improving the fatigue life of the the wheels. I've owned both, although I don't know of any catastrophic failures of the first gen wheels, the second gen wheels are much better.
  14. KC Jr 54
    KC Jr 54 New Member
    Jun 3, 2009
    402
    20
    Machine Operator
    Tyler, TX
    #34 KC Jr 54, Mar 5, 2011
    I was actually able to get away w/o the spacer in the rear. Difference in molding of trailing arms i suppose. Without the spacer though, i can NOT use hammer on weights on the inside, like it is commonly done. Doesnt effect me at all, but good info to have.
    mini_racer, looks like our cars are almost visual twins lol. DS w/ Nickel 6ul's. Ive had mine for a little over a year now, and freakin love them! W/ the correct tire, the wheel gap isnt bad at all. The above photo has my front roughly 1.5" down, and with a 225/50-15 tire (24"ish tall).
  15. mini_racer
    Engr Manager
    You are definitely one of the lucky ones that do not need the spacers, I have read that some cars just don't need them and your car proves it.
    My tires are Hankook RS3s in 225/45-15, a little smaller in diameter and so a little more gap.
    What studs do you have and how long are they? I am going to have to move to studs one day.
    Yeah those Nickel finish wheels look pretty damn good with DS.
  16. KC Jr 54
    KC Jr 54 New Member
    Jun 3, 2009
    402
    20
    Machine Operator
    Tyler, TX
    I think these are a Helix kit or something. What ever they are, they need to be off of my car. I had a set of TSW ones as well, and wasnt super impressed with them either. Nothing against TSW/WMW, but there are better options.
    Turnermotorsports are the way to go IMO. More costly, but hands the best option out there w/o drilling out your hubs for a press in stud.
  17. ColinGreene
    ColinGreene Well-Known Member
    438
    293
    Orange county Ca
    I think that someone makes a real stud kit for these wheels in a 14mm, if your going to go to the trouble of drilling it out why not buy a set of real racing studs with a porsche lug nut pitch to make it easier to find the nuts vs the mini's strange pitch.
  18. minimark
    Yep think RMW has them! ;)
  19. mini_racer
    Engr Manager
    #39 mini_racer, Mar 6, 2011
    So, why do you like the TMS so much, they seem pretty long at 75mm, but they do have a nice finish on them. Also, what is the issue with the other options you mentioned?
  20. howsoonisnow1985
    Aug 8, 2009
    171
    Inmate
    Thanks guys, I think I'll pass on them and wait for some 2nd Gen wheels. I really like the look of the Black Center with the Machined Lip though.:(
