Fes-Auto Prolight shifting system $75.00 Fes-Auto 4 way relay switch $35.00 Sprint booster with 3 level switch automatic $200.00 Okada plasma booster $80.00 I accept paypal and will ship USPS priority flat rate. all parts are in excellent condition or new. Shipping is included. I also will accept offers. Thanks for looking. I accept paypal and will ship USPS priority flat rate. all parts are in excellent condition or new. Shipping is extra unless noted with part. I also will accept offers. pics are available. Thanks for looking.
The TrackCoach™ ProShift High Current Relay Module contains four separately fused channels that can each switch up to 15 Amps of current. While this relay module was specifically designed as a companion to our shift lights, it can be used independently in your own setup. It’s rugged enclosure and high quality automotive relays make it the perfect choice for your high current switching needs. Our customers used it successfully to integrate items like for example intercooler sprayer pumps, seat heater or radar detectors. * Features***|*** Image Gallery***|*** Downloads & Documentation***|*** FAQs Features 4 Fused Channels Safety is important. Because of this, we integrated a fuse with each control channel. The unit comes standard with 15 amp fuses. We used industry standard Littlefuse Series 297 automotive Mini Fuses, available from pretty much any auto parts store. High Quality Automotive Relays We've selected Panasonic's high capacity automotive relays, capable of switching up to 15 Amps. You can check out the relay datasheet here. (Opens in a new Window). Rugged Enclosure - Small Dimensions The relay module comes in a sturdy plastic enclosure with a metal baseplate. Dimensions are: 2.28" (58mm) x 2.99" (76mm). Robust Terminal Blocks We have selected terminal blocks from Phoenix Contact that offer robust and easy connections to your load. Hope this helps answer your question. Copied this from fes-auto website.
