MINI 1st Gen 2002 MINI Cooper motor mount
Discussion in 'MINI' started by Ernesto, Jan 2, 2023.
  1. Ernesto
    Ernesto Club Coordinator
    May 16, 2009
    652
    676
    Oracle DBA
    Skokie Ill
    I noticed the passenger side motor mount on my 2002 Cooper puked it's fluid out the other day.
    I am not super mechanically inclined, but thought I'd give it a go fixing it myself..
    We'll see how it goes.
    Here is the original yuck
    I ordered up a new mount and upper mount from waymotorworks should get here in a couple more days.
    I thought I'd knock out some prep work before the parts arrive, but removing the 20 year old plastic rivets (and rusty screws) has kicked my butt so far. Off to the store get some more tools to help make it easier.
  2. 00Mini
    2,237
    Sorry you’re having problems but at the same time encouraged to know that I’m not the only one who starts a seemingly small project only to find out the scope and difficulty factors have all of sudden escalated.
  3. Ernesto
    May 16, 2009
    652
    676
    Oracle DBA
    Skokie Ill
    After a mental and physical break, I ran off to the store to get a proper tool to help remove the plastic rivets.
    Worked really well on most of the rivets but two were so stripped and damaged I had to go ape $hit on them to get things apart.
    The final rivet would not release even after I was able to get the fender liner out. I was finally able to work it out, but I took some collateral damage in the form of broken clips to hold the plastic wheel arches on. Some were previously broken, but now I am not able to get the arch re-attached until I procure some new clips.
    Fender liner is finally off, and I cleaned that and a few other interior parts that have not seen the light of day in over 20 years.
    The engine mount bolts are all sprayed and I will do battle with them another day.
  4. Ernesto
    May 16, 2009
    652
    676
    Oracle DBA
    Skokie Ill
    Yea.. Happens more than I like, but I am almost always able to get myself out of the jams I create. Stuff is usually harder than the videos I watched to become YouTube certified in these repairs.
    Not surprising since the stuff is so old. That once nice plastic that some engineer spec'd has turned into a brittle mess. This seems to happen to me on a regular basis. Once you are done it's good for another 20 years! Plus you got to buy a new tool.
    Pretty sure my ortho doc had to run over to Harbor Freight for a new bone saw when he did my knee. At 71 my parts were really rusty & brittle. o_O
  6. MCS02
    6,293
    If you cant get the center screw out that will not budge! The next time I have one of those devils stuck I am going after it with a drill.
  7. Ernesto
    May 16, 2009
    652
    676
    Oracle DBA
    Skokie Ill
    Skid plate came off pretty easily.
    Next I have a bunch of engine greasyness to clean up and see if I can start loosening the engine mount bolts.
    New parts are expected later today.
    Unfortunately my real job will be getting in the way of my MINI job for the rest of the week, so I'll have more limited garage time.
  8. 00Mini
    2,237
    #8 00Mini, Jan 3, 2023
    Whoa !! A red skid plate with a racing stripe…..that’s gotta be worth 5-8 horsepower !! :D:D
  9. Ernesto
    May 16, 2009
    652
    676
    Oracle DBA
    Skokie Ill
    Yea.. the carpet matches the drapes.
    If anyone sees my car upside down in a ditch, you'll know who it is
  10. Ernesto
    May 16, 2009
    652
    676
    Oracle DBA
    Skokie Ill
    Made a bit more progress last night and this morning.
    The passenger side mount bolts loosened up pretty easily, and everything came apart without too much difficulty.
    The old mount was pretty nasty looking
    The engine and motor mount bracket was covered in a thick layer of yuck, so I will take some time to clean things up before putting everything back together.
    I am thinking of giving this bracket a quick spray of black after cleaning and before putting it back together. This is after the first round of degreasing.
    The replacement of the upper engine mount is proving to be more difficult. I didnt realize the end of the bolts went thru the body and were exposed and heavily rusted. They did loosen, but are still very difficult to turn and I dont have enough space to get my breaker bar on 2 of the bolts.
    If I had a short 16MM socket with 1/2 inch drive it might work, but I only have a long 16MM with 3/8 drive.
    I've re-sprayed everything more and will get back to it later today or tomorrow.
    Not sure what you are using, but I've had good success with Aero Kroil to help loosen rusted carp. While not cheap it does work the best of anything I've used.
    Once you get those bolts out, wire brush them & then coat them with anti-seize.
    https://www.ebay.com/itm/254383757848
  12. MCS02
    6,293
    That really looks fun! I wish I were there I would do it just for the fun. Some people have all the luck!:D
  13. 00Mini
    2,237
    I’ve used Kroil oil before and it works.
  14. Ernesto
    May 16, 2009
    652
    676
    Oracle DBA
    Skokie Ill
    The upper engine mount is now removed using a bit of leverage. My old cheap in-the-car socket wrench gave it's life for the cause and I needed to complete the job with my even older in-the-house craftsman wrench.
    The upper mount did have some cracks visible after I removed it, so I am glad I went thru the effort to pull and replace it.
    Next up is more engine gunk cleaning and painting of the motor mount bracket and things can then start going back together.
  15. 00Mini
    2,237
    Good job … and you were able to muddle through it without the assistance of our illustrious and most thoughtful leader MCS02. :)
  16. Ernesto
    May 16, 2009
    652
    676
    Oracle DBA
    Skokie Ill
    Motor mount bracket is now painted flat black..
    Time to start re-assembly
  17. 00Mini
    2,237
    It’s amazing how a coat or two of paint really completes a job.
  18. MCS02
    6,293
    Looks good!
  19. Ernesto
    May 16, 2009
    652
    676
    Oracle DBA
    Skokie Ill
    The big stuff is done.. Assembly was much easier than dis-assembly.
    Waiting on plastic clips to re-attach the inner fender and wheel arch, which will be next week.
    Then I can get the wheel back on and the skid plate re-mounted and do a proper road test to see if it actually feels different.
    The painted bracket looks really sharp. The unpainted drivers side mount now looks out of place to me, (but not enough to take that side apart at the moment)
    Overall parts cost was about $180 for the 2 mounts and plastic rivets and clips that I broke on dis-assembly.
    Tools cost for stuff I didnt previously have (16MM, 18MM, e12 torx sockets, and a plastic clip pry tool) was about $30.
    Satisfaction for doing the job myself instead of taking it to my repair guy.. priceless.
    • Winner Winner x 3
    • Like Like x 1
  20. MCS02
    6,293
    Job well done. That always feels good!
