1st Gen R50 Cooper 2003 Cooper radio aux input question
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by flashover604, Nov 19, 2015.
  1. flashover604
    flashover604 New Member
    Mar 11, 2015
    33
    Phone man
    Lancaster, Ohio
    Hi all. I have a 2003 base model Cooper. It has the stock radio with no auxiliary input. I know that there are many harnesses to add Aux IN to the radio, but I've heard that there are some radios that will not work. Even if the harness fits, there's no Aux input. My radio cycles through FM/AM and cd. There is no aux option. Does the harness need plugged in before the "AUX" option is added to the cycle?
  2. nkfry
    nkfry New Member
    Roseville, MI
    Based on build date, the early 02 builds will not have an aux function.
    The radio won't show "aux" unless there is a jack installed it will only cycle through the available options until you install the harness.
    Check your drivers door jam for the build date.
    Aux Jack
  3. flashover604
    Mar 11, 2015
    33
    Phone man
    Lancaster, Ohio
    I picked one up off of eBay for $6.xx shipped from China. Felt around behind the radio and found the port, plugged it in, turned the radio to Aux and had George Strait piping from my iPhone through my speaker in less than five minutes... Thanks for the help!
  4. MCS02
    6,293
    Something must have gone terribly wrong. Why would the Aux port play such bad music? Thats what happens when you buy parts from China.:D
    Ok here you go!
    [ame="https://www.youtube.com/watch?v=lMNw_-yUm_0"]George Strait All My Ex's Live In Texas Live - YouTube[/ame]
  5. daviday
    daviday Active Member
    Jan 15, 2014
    140
    25
    I of course pulled the whole center apart. If you were really able to get it in there with out taking anything apart I feel like a real dummy. The one odd thing about mine is that if I have whatever device connected to the aux input and charging at the same time, aux will not be an input option.
    Anyone else experience this?
  6. rkw
    rkw Well-Known Member
    443
  7. mrntd
  8. daviday
    Jan 15, 2014
    140
    25
    Thanks for the tip. :)
