1st Gen R53 Cooper S 2003 Mini Cooper S Stuck in neutral
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by cmarshall, Dec 13, 2015.
  1. cmarshall
    cmarshall New Member
    Dec 13, 2015
    11
    So I recently bought my first mini cooper. I was able to get it for a good price because it has an issue... it's stuck in neutral. The shift lever will not move in ant direction and is seized in neutral. I disconnected the linkages and the lever moved freely. Could this be a clutch/throw out bearing? The location where the linkages connect to the transmission seems to be the culprit, or possibly the transmission itself? Has anyone else ever ran into this issue or have any ideas for a solution?
    Thanks
    If it's a stick shift its most likely your clutch slave cylinder. They are know to fail.
    It a cheap fix at the dealer and I would suggest have your clutch master cylinder done at the same time. (I did)
    I had the dealership do the job because it is a real pain in the ass to bleed the slave cylinder.
  3. wmwny
    4,048
    2,246
    Welcome to M/A! :Thumbsup:
    I'd follow Dave's lead as he is a pretty savvy R53 guy.
  4. cmarshall
    Dec 13, 2015
    11
    I have the whole front bumper off and I can see the clutch slave cylinder actuate when the clutch is applied. Would it still be possible that it's not fully engaging/disengageing and would cause the shifter to be ceased in place?
  5. papa-j
    papa-j Active Member
    378
    112
    Minneapolis, MN
    How-to in the Library
    Hi, hopefully helpful - there is a clutch slave cylinder replacement "how-to" posted in the MA library. It may be good to visualize the steps.
    LINK to Instructions
  6. ColinGreene
    ColinGreene Well-Known Member
    438
    293
    Orange county Ca
    can you move the linkage on the trans by hand at all?
  7. cmarshall
    Dec 13, 2015
    11
    I disconnected the linkages from the shifter to the transmission. Once I did that I could move the shifter in all positions. However the linkages mounted on the transmission itself seems to be seized up. They will not move by hand.
  8. MCS02
    6,294
    I will defer to Colin on this one,but I would say its time to rebuild the transmission and put a new clutch in. Even with the clutch engaged if the motor is off you should be able to move the leakage on the transmission.
  9. ColinGreene
    438
    293
    Orange county Ca
    If you can move the linkage with the car not running then you have a internal problem.
  10. MCS02
    6,294
    Ok you correct. I ment the shifter but I forgot he had un hooked it. Sorry
  11. cmarshall
    Dec 13, 2015
    11
  12. BruceK
    BruceK Active Member
    Feb 24, 2015
    Texas
    Super news! Glad you figured it out and it cost you nothing in parts or labor (other than your time). The fact you got the car for a good price because of the issue is icing on the cake.
    I wonder what caused it to seize? Perhaps the car was not driven much and it seized out of inactivity?
  13. fishmonger
    fishmonger Well-Known Member
    May 13, 2015
    984
    769
    Madison, WI
    you're not supposed to crawl under the car and tighten random rusty bolts!
  14. Detroit Tuned
    319
    evertyhing
    Metro Detroit
    Based on that photo you for sure need new shift cables.
    Chad
    Detroit Tuned
  15. Metalman
    7,689
    The upper right ball joint looks like its popped out of it's housing....
    If so, don't expect it to last very long... And it will fail when you are driving on a dark country road in the middle of a blizzard many miles away from help....
    Get it fixed ASAP...
  16. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    ^This^
  17. cmarshall
    Dec 13, 2015
    11
    Yeah the whole assembly is being replaced, cables and brackets and all.
