2005 R52 fuel filter change issues
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by minyme, Apr 25, 2022.
  1. minyme
    minyme New Member
    May 24, 2015
    23
    15
    R52 Base mini. Half a tank of fuel. Changed fuel filter. Now won't start. Taken it apart three times. The level sensor and the hose with the other metal arm "popped" off. Reinstalled those. Still no start. Fuel pump is priming. So I decided to take the line off of the filter housing, fuel comes out if there but no fuel out of the line. Suggestions??
    Sent from my SM-N960U using Tapatalk
    6,293
    I am not sure I follow. I think you are saying the fuel is coming out of the filter so the filter is not blocked. But what is the line that fuel is not coming out of?
    Have you checked the fuel pressure at the rail? The pressure at the rail should be 43.5 +/- 3 psi.
  3. minyme
    minyme New Member
    May 24, 2015
    23
    15
    Here's a picture. Sorry to be so vague and confusing.[​IMG]
  4. 00Mini
    2,237
    I was going to reply earlier that if filter is not seated properly the car will not start but I reread your post and it stated that you have taken it apart and put back together three times so I held back from commenting. Is it possible that there is a problem with the o-ring on the filter ??
  5. minyme
    minyme New Member
    May 24, 2015
    23
    15
    Possible. I will recheck that sometime in the next few days.
  6. minyme
    minyme New Member
    May 24, 2015
    23
    15
    Update
    Ordered an oem filter kit. Put the new seals and filter in. Fired right up.
  7. 00Mini
    2,237
    Always good to hear back how things went …. good or bad.
