2006 Cooper S [Portland, OR]
Discussion in 'Classic Mini, MINI and other Cars for Sale' started by Bmichael, Apr 18, 2016.
  1. Bmichael
    Bmichael New Member
    Apr 18, 2016
    My Sooper Cooper is for sale. It's in great condition, has been properly maintained, is professionally modified.
    Factory options:
    Sport package (Fogs, DSC, Xenon lights)
    LSD
    Chrono gauge pkg
    Harmon Kardon stereo pkg
    Leather interior
    Dual Moonroofs
    Maintenance (I have years of records):
    New clutch @ 28k
    New water pump, temp sensors, angle sensor, thermostat @ 67k
    Supercharger oil service, coolant flush, crank sensor o-ring, PCV valve, MAP sensor, NKG spark plugs, ignition wires, coil and LCA bushings @ 80k
    Throttle body @ 90k
    Belts replaced @ 95k
    Fresh oil change, new front & rear wiper blades, and wheels aligned last week
    Performance (also have records, all engine work done by Madness Motorworks):
    Thumper TPR1 performance head w/ ARP bolts
    CAT cam w/ cam gear (FYI, big cam affects idle)
    550cc injectors
    DDM Works intake
    GP intercooler
    DDM Works intercooler diverter
    Ported intake manifold
    15% SC pulley
    OBX 4-2-1 header
    Milltek exhaust
    AEM AFR gauge
    Tuned by Bytetronik (tuning tool included)
    IE Fixed camber plates
    Koni yellow shocks
    JCW springs
    19mm rear anti-sway bar
    Mini Madness under-carriage brace
    M7 "anti-mushroom" plates and strut brace
    Poly bushings all around
    SS brake lines
    StopTech rotors/pads
    The car has been running good with these parts for the last 20k miles.
    I also installed GROM Audio's Bluetooth & AUX connections. Very handy.
    It also has automated fog lights and window roll-up. Very handy x 2.
    I'm including the Schroth 4-point harness with the car. It's DOT approved for road use, super useful and takes 30 seconds to take in/out.
    101k miles. No rust, no accidents. Full records. I'm the 2nd owner. The only thing not working on the car is the AC.
    This car pulls. Perfect for canyon carving, begging for AutoX.
    $10k
    I can provide clean carfax report at request.
    6,293
    Nice looking Mini!
  3. Grizld700
    Grizld700 Well-Known Member
    Feb 2, 2016
    1,212
    47
    Eastern Iowa
  4. 00Mini
    2,237
    Beautiful R53 !! Good luck with the sale.
