2nd Gen 2007 cooper s turbo not starting massive missfire codes. help!
Discussion in '2nd Generation: 2007+ R55 through R61' started by CIN, Jun 7, 2018.
  1. CIN
    CIN New Member
    Jun 7, 2018
    Hi
    First this is my first post here :)
    I have an automatic 2007 mini cooper s turbo and it has developed a starting problem.
    So the mini had an engine light come on. I decided to take a look with the obd reader.
    It had multiple misfire codes. I cleared them and the car has not been able to start anymore. Sometimes it starts for a few seconds and it dies. Engine is obviously miss firing. I can manage to rev it up a bit but it still auto shuts off even while giving it some throttle.
    I read a bit around and many people seem to have problems with the hpfp on the side of the engine. I checked the fuel pump in the tank and that seems to be working fine. I also changed the hpfp but still the same issue. Car turns but does not start and when it does it dies immediately. Check engine comes on and shows multiple missifires. Most of them are on cyl 3 and 4.
    Can somebody help me sort this out please?
    Thanks
    Joe
  2. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    A misfire can be as simple as needing new plugs and/or coils. My first misfire was a HPFP, but the next one was coils.
  3. CIN
    CIN New Member
    Jun 7, 2018
    Thanks for the reply. The strange thing is that it worked ok before I cleared the engine light. as soon as I cleared that it never started again.
  4. MCS02
    6,293
    How many miles do you have on your Mini? Also when was the last time you had the intake valves walnut blasted to remove carbon build up? Some people make it to 70k but I know some people have it done as low 40k. Clearing the codes did not hurt anything.
  5. Qik
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    They'll go in and out when nearing end of life.
  6. Sully
    Sully Administrator
    Jul 21, 2015
    2,100
    916
    Software
    30350
    Is this still the case (i.e. starts sometimes) or is this still the case
    If this is the case - sounds like you have confirmed Fuel.. next for me would be to confirm spark (especially with the codes its throwing). Have you confirmed you are getting spark?
    For me that would be the next step. If its turning over, you have fuel, but no start (or even what sounds like its trying to start).. I would confirm spark and that the plugs are not fouled.
  7. MCS02
    6,293
    If those intake valves get coked up enough it wont start either. Its an N14 engine with direct injection. The PVC system is not the best design I have seen.
  8. Neil
    Neil New Member
    Jul 25, 2018
    6
    Starting and dying sounds like hpfp. If you don’t have a fuel pressure testing kit you’ll need to get that tested at a local shop. If you have the tools you want 5 bar going into hpfp and about 50 bar going to the rail at idle.
  9. Minidave
    4,621
    I agree with testing things before you start throwing parts at it.
    First, test compression......timing chains are an issue with these engines.
    If compression is at least even and enough, then check the fuel pressure. If that's OK go on to the ignition system - coils and such. You'll already have the plugs out to do compression so that might give you some clues too.
  10. caseydog
    caseydog Well-Known Member
    Nov 7, 2012
    2,433
    879
    Automotive Photographer
    Dallas
    If it keeps showing missing, I'd check the coil packs. Two out of four coil packs going out would make it hard to keep the car running. On other cars, I've had multiple coil packs fail within weeks of each other, so it wouldn't surprise me to see two go out at about the same time.
    CD
  11. Dave.0
    Coil packs test and then walnut blasting the intake valves.
