Year: 2007Make: MINIModel: HardtopPrice: $6500Mileage: 108646Color: Mellow YellowPrivate or Dealer Listing: Private ListingLocation (Region): Texas Mods MINI Limited Slip LSD EBC Redstuff Brakes Forge Intercooler Bilstein B14 Coil Overs (same as GP) H*Sport Rear Camber Links Upper and Lower set TSW 19mm Rear Sway Bar and NM Rear Sway Bar Links Mini Cooper Challenge Rear Exhaust - Cat Back RennTech Tune JVC Radio, JBL Speakers, Kenwood powered sub JCW 17" Wheels NEW BFG g-Force Comp2 Tires Maintenance Chain Tensioner and Timing Chain High Pressure Fuel Pump (HPFP) Turbo Heat Shield and Aux Water Pump Water Pump Oil Filter Stand Gasket, Cat Gasket and Turbo Oil Lines Front Crankshaft Seal New Valve Cover and Seal New Clutch & Flywheel Upper Radiator Hose and Flush Cooling System Upper O2 Sensor NGK Plugs Windshield New Headlights Battery Issues Airbag Light (Airbag module, ~$100) Seat Seam Link to album: https://goo.gl/photos/6nVijDD8BQKAZV35A -------------- For more info, click here to view the original listing: 2007 MINI Cooper S w/ LSD - Mellow Yellow --------------
