2007 MINI Cooper S w/ LSD - Mellow Yellow
Discussion in 'Classic Mini, MINI and other Cars for Sale' started by Eric_Link, Oct 27, 2016.
  1. Eric_Link
    Eric_Link New Member
    Sep 28, 2015
    46
    20
    Mods (all over the last 24 months)
    • MINI Limited Slip LSD
    • NEW EBC Redstuff Brakes
    • Forge Intercooler
    • Bilstein B14 Coil Overs (same as GP)
    • H*Sport Rear Camber Links Upper and Lower set
    • TSW 19mm Rear Sway Bar and NM Rear Sway Bar Links
    • Mini Cooper Challenge Rear Exhaust - Cat Back
    • RennTech Tune (+40hp/tq)
    • JVC Radio, JBL Speakers, Kenwood powered sub
    • JCW 17" Wheels
    • NEW BFG g-Force Comp2 Tires (Light and sticky, no run flats!)
    Maintenance
    - All Service Campaigns Done over last 24 months -
    • Chain Tensioner and Timing Chain
    • High Pressure Fuel Pump (HPFP)
    • Turbo Heat Shield and Aux Water Pump
    • Water Pump
    • Oil Filter Stand Gasket, Cat Gasket and Turbo Oil Lines
    • Front Crankshaft Seal
    • New Valve Cover and Seal
    • New Clutch & Flywheel
    • Upper Radiator Hose and Flush Cooling System
    • Upper O2 Sensor
    • NGK Plugs
    • Windshield
    • New Headlights
    • Battery
    Issues
    • Airbag Light (Airbag module, ~$100)
    • Seat Seam
    Link to album: https://goo.gl/photos/6nVijDD8BQKAZV35A
  2. 00Mini
    2,237
    Good luck with your sale.
