2nd Gen R60 Countryman Most liked posts in thread: 2011 CMS sputters when startup in the morning
  1. old81
    1,542
    Plugs and/or the HPFP. Should be warranty on the HPFP and the plugs need to be changed at 50K, sometimes sooner depends if you do short drives or a lot of highway. Short drives, replace the plugs.
    I plan on replacing my 11 CM plugs in the next two weeks at the dealer, brakes will be done by an independent shop with parts I like.
    6,278
    How cold was it and how old are the plugs?
  3. Minicountry
    Minicountry New Member
    May 15, 2014
    6
    2011, 8-10 celcius. What about the HPFP?
  4. Minicountry
    May 15, 2014
    6
    Thanks:Thumbsup:
  5. dbow32
    dbow32 New Member
    Jan 4, 2018
    Also could be the High Pressure fuel pump. There is a extended warranty on this part so should be free.
    Sent from my SM-G955U using Tapatalk
  6. CHKMINI
    Could be build up on the intake valves and it needs walnut blasted. My wife’s 11CMS had the same issue.
