2011 Mini a/c questions
Discussion in 'Starting Line - New Member Introductions' started by Waltguy, Aug 9, 2017.
  1. Waltguy
    Waltguy New Member
    Apr 10, 2017
    Bought our son a 2011 Mini Cooper hatch for graduation. We've been unable to find where the refrigerant is leaking, unable to find any signs of the dye. Has anyone else experienced this problem?
  2. eMINIparts
    eMINIparts Well-Known Member
    3,751
    1,087
    MINI Parts Advisor
    Bedford NH
    I've seen leaks in the condenser that doesn't show any signs of leaks, I've also seen the Schrader valves be the problem as well.
    Not saying that is it, but just some of the ones that were not easily found.
  3. Waltguy
    Waltguy New Member
    Apr 10, 2017
    We did find a leaking schrader valve, replaced it. But now the system has less than .10lb of R134 and no signs, Condenser? Evaporator? Which one is under the dash? And how hard is it to get to? Thanks
  4. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,418
    662
    IT
    Atlanta-ish
    The evaporator on an AC system is in the dash.
