2nd Gen R60 Countryman 2012 Mini Countryman R60 Tail Light
Discussion in '2nd Generation: 2007+ R55 through R61' started by paulm, Nov 2, 2017.
  1. paulm
    paulm New Member
    Nov 2, 2017
    Odd tail/brake light issue: the upper bulb on the right taillight cluster won't work. I switched bulbs and the bulb is fine. Performed a continuity check of the cluster and it's fine. I would like to find a good wiring diagram or service manual to further diagnose and/or has anyone had this problem too?
    6,293
    Welcome to MA. It sounds Like you have probably done this but did you try unplugging the wiring harness from the back of the housing and plugging it back in to make sure it was seated? The only other thing did you put the multi meter on it to make sure it was getting 12v when the brake is pressed? If you don't have a Bentley manual you may want to get one they are very helpful. I am on the road but when I get home I will take a look and see if they have a good digram in ti.
  3. 00Mini
    2,236
    Good suggestions by MCS02 and Welcome to Motoring Alliance !!
  4. paulm
    paulm New Member
    Nov 2, 2017
    Thanks for the replies. I have performed most of the tests proposed hence the need for a wiring diagram. I would love a Bentley's, but haven't found one for the R60 Countryman. Any suggestions?
