1st Gen "How To" 6-Speed Automatic Transmission Fluid Change
This guide is primarily aimed at 2002-2006 Mini Cooper S models equipped with the Aisin-Warner TF60-SN 6-speed transmission. Other models are...
By fishbone · Jan 23, 2018 ·
Rating:
5/5,
  1. fishbone
    fishbone New Member
    Dec 25, 2011
    12
    Calling all auto owners :)
    The R53ers have the procedure pretty much nailed down.
    No, there is NO such thing as lifetime fluid. Yes, you HAVE to change it sooner or later.
    We need your help with writing up a DIY for the 2007+ Mini owners.
    We need to identify if the Base Mini/Clubman/Countryman and their S counterparts share the same 6-speed Aisin-Warner Transmission.
    The R53 uses the TF60-SN and it SEEMS so do all the new models that use the 6-speed auto but we need to confirm. Here is the relevant thread in the R53 section, along with a DIY I wrote up and attached as a PDF.
    http://www.motoringalliance.com/forums/cooper-s-engine-drivetrain/12459-02-06-mcs-6-speed-automatic-transmissions.html
    Thank you and let's keep up on maintenance for happy motoring!
  2. fishbone
    fishbone New Member
    Dec 25, 2011
    12
    Can someone help me out with the R's?
    I'm ashamed to admit I only know the 2007+ is the R56
    What about the 2007+ base Mini, Clubman /S and Countryman /S?
    RealOEM.com and a parts guy are coming through, here is what I have found out so far.
    Some Mini S use the TF-60SN and others use the TF61SN from 2005 to 2012
    The clubman / coupe / Mini could also have the TF70SC from 2011-2012
    The Countryman from 2011-2012 has the TF61-SN and in 2012 the TF61SN or the TF70SC
    So! Time to look up how the TF61 and TF70 are different and what impact that has on the DIY.
  3. fishbone
    fishbone New Member
    Dec 25, 2011
    12
    Here is the guide. I will be checking in here and letting you all know when I post an updated version.
  4. Lex2008
    Lex2008 New Member
    Nov 23, 2014
    • Informative Informative x 1
  5. wmwny
    4,040
    2,242
    Welcome to M/A!
    The article to which you are referring was written 4 years ago. However, that said, a BIG THANKS for your update!:Thumbsup:
    On the downside, though, does this remedy solve the problems with the R53 automatics?
    I have 2 of them as well as an R50.
  6. Sully
    Sully Administrator
    Jul 21, 2015
    Software
    30350
    Agreed - Welcome to MA and posting a link to this article. Good stuff. :Thumbsup:
