1st Gen R53 Cooper S a/c problem
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by MCS02, Sep 12, 2009.
  1. MCS02
    Hi
    I hope someone can help. Last night my A/C quit. I was driving home on the highway the A/C was blowing cold; my son told me he was cold. I turned off the A/C (fan to off), it started to get hot so I turned the fan back on. The air never got cold again. Today I just had time to do a quick check, fuses look good and I unplugged the relay to make sure it was plugged in good all seemed ok.
    When I turn on the a/c the green light comes on but the car does not idle up, I can’t hear the compressor kick in (it may be but I cant tell), and the radiator fan does not come on.
    The radiator fan and power steering fan are both 6 months old and do come on once the car gets to running temperature so I don’t thank it’s the fan.
    I don’t think its low on refrigerant because it happened so fast, but could be.
    Sorry for the long post.
    Thanks Lee
    P.S. 02 CooperS
    The gnomes have stolen my brains I hope the flying monkeys haven’t taken my R134
  2. k-huevo
    k-huevo Club Coordinator
    159
    Pipe Creek, Texas
    Engage the P-brake, start the car, pop the hood, stand near the compressor side, have an assistant turn the AC on, if you can hear the compressor working and can see extra vibrations of the motor, the compressor is good, so have the refrigerant checked. If you’re very observant you can see the clutch kick in. If when the AC is turned on/off you don’t see or hear an operational difference, the compressor clutch has failed. The fact the loss of cooling capability was abrupt, sounds like the compressor clutch.
  3. MCS02
    Thanks for the help. It looks like the clutch is not working. Do you know if I can replace just the a/c clutch or do I have to get the hole compressor. From what I can see it is going to be a pain to get to.
    Thanks again for the help
    Lee
  4. K5Cruiser
    K5Cruiser New Member
    Do you have the automatic climate control? Are you sure the A/C is actually on?
  5. MCS02
    No I do not have the automatic climate control. I get the green light in the a/c button and the blower fan comes on. The radiator fan does not turn on and the clutch does not engage. I plan on checking to see if its getting power to the clutch.
