A Good Old "What Wipers, Fuel, Oil, Air Filter or Tires do You Use" Thread
Discussion in 'MINI' started by Nathan, Jun 19, 2015.
  1. rkw
    rkw Well-Known Member
    443
  2. Spa2k
    Spa2k Well-Known Member
    May 9, 2013
    1,955
    975
    Iowa
    Wow, rkw, after reading those definitions we should leave you and JECO alone here - he's busy quibbling his oracle in message #10. :ihih:
  3. rkw
    443
    Hey, I didn't come up with those definitions. I'm just the messenger. :D
  4. mrntd
    PIAA super silicon (thanks savvy and Dave)
    93 without ethanol
    Castrol synthetic
    K&N JCW flapper less box
    Hankook ventus v12, Contiental dws down to just dw
  5. ZippyNH
    #25 ZippyNH, Jun 21, 2015
  6. Rawhyde
    Rawhyde Active Member
    Apr 7, 2012
    311
    233
    Facilities Engineer
    Mountains of NW Georgia
    I'm having a hard time trying to figure out whether post 4 or 5 wins the internet. One of them does, but both are epic....
  7. ZippyNH
    I'm not sure if I should laugh or cry....
    The other sites thread on draining the coolant tank went the same way...
    I guess we all know somebody like this...my brother-in-laws for one...but he learned, that he IS NOT ALLOWED TO PICK UP A TOOL......
  8. caseydog
    caseydog Well-Known Member
    Nov 7, 2012
    2,433
    879
    Automotive Photographer
    Dallas
    Wipers: Bosch
    Gas: Usually COSTCO. It all comes from the same terminal, only the additives are different (added to the tanker truck) by brand. I prefer a busy station where the fuel doesn't sit in the underground tanks very long.
    Oil/Filter: MINI/MINI
    Air Filter: MINI
    Tires: Bought some Hankook Ventus S1 Noble2 tires six months ago. VERY happy with them.
  9. caseydog
    Nov 7, 2012
    2,433
    879
    Dallas
    Yeah, I'm repeating myself, but I hope people realize that if you buy your gasoline at a Chevron station, for example, it does not mean your gasoline came from a Chevron refinery. Chevron's Techron additive is added to the gasoline when the gasoline is loaded into the tanker truck at a gasoline terminal. That is the only thing that makes it Chevron gasoline.
    Where the terminals get their gasoline depends on where they are located.
    CD
  10. caseydog
    Nov 7, 2012
    2,433
    879
    Dallas
    Coolant: Pentosin Pentofrost NF
    Washer Fluid: Whatever is cheap
  11. beken
    beken Well-Known Member
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
    Wipers - PIAA
    Fuel - Shell V-Max 91 oct (no ethanol), Chevron 94 oct
    Oil - Castrol Syntec
    Air Filter - Madness CAI
    Tires - Yokohama Avid Envigor
  12. TheModFather
    Wipers- Not too often
    Fuel- 91 with 10% ethanol (blame the Colorado tree huggers)
    Oil- Rotella T6 synthetic... Lots of ZDDP, and no dinosaurs
    Air Filter- Tube Sock
    Tires- whatever is sticky and has a treadwear of 200 or less.
  13. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    What weight do you recommend Dave.0? I just changed mine with some 0w40 Euro mobile 1. Engine seems a tad noisier than usual.
  14. Qik
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    1.OEM
    2.Either 93 Shell or QT Or Sams Club.. OR 90 ethenol free
    3.Usually Castrol Syntec
    4.AFE Dry Drop in
    5.Factory recommended at the moment
  15. MCS02
    1 Windshield wipers are for wimps!
    2 The cheapest gut rot I can find, the more ethanal the better. for me and the Mini
    3 I use straight 50 weight, the sludge that builds up helps catch metal chips
    4 It breathes better without a filter.
    5 all season run flats from china 194 R70 17
    I hear some people like 0w-40 but what do they know?:D
  16. Qik
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    From the research I've done I decided to take out the 40 and put back the 5w30. The conclusion I came to is the 40 is just a tad to heavy/thick May sound crazy, but the car feels a bit sluggish compared to before. At idle I feel the engine in the car more so then before.
  17. vetsvette
    Sigh...
    :postcount
