1st Gen R53 Cooper S AC Compressor on it's way out
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by mini_racer, Jul 13, 2009.
  1. mdbsat
    mdbsat New Member
    Finance
    San Antonio
    I did that before the AC stopped working. The guy at the shop I took it too this weekend said never to use those with any kind of sealant on our cars. He thinks thats what killed my AC:(
  2. Rae
    Rae Club Coordinator
    Oct 14, 2010
    907
    Oregon
    Bummer, the car that we charged a couple of months ago is still running great, and cold. But we don't use the AC often, we may just be postponing the inevitable. Guess we'll wait and see.
  3. HRM
    HRM New Member
    Mar 16, 2011
    74
    10
    Not all of the cans have a sealer included in case you are concerned, but I would recommend using one that contains dye. If it turns out to be a bad leak, you will be more likely to find it easily so it can be fixed once and for all.
    I got lucky and a can has worked all summer. I am thinking the cold shrinks the gasket. If it leaks again this winter I should be able to find the dye and fix as needed. I also went around and very gently tightened all connections just in case something shrunk.
  4. RayanMX
    RayanMX New Member
    Mar 8, 2011
    So as long as we don't use one with sealant, it's oK then?
  5. BlimeyCabrio
    My AC had been trouble free for 113K miles, other than needing a recharge last year... but now has started the compressor "howl".
    Oy vey.
  6. Crimson
    Crimson New Member
    Jul 11, 2012
    10
    My ac blows hot air, being in phoenix I NEED COLD AIR.. was told by a mechanic the compressor has failed. I have been reading a few things and wanted your all opinions. Is replacing the compressor and drier a DIY capable job. Or should i have a shop do it for me?
  7. Crimson
    Crimson New Member
    Jul 11, 2012
    10
    Looking for a diagram on where the drier goes, anyone have a diagram of this portion of the engine?
  8. k-huevo
    k-huevo Club Coordinator
    159
    Pipe Creek, Texas
    #28 k-huevo, Jul 21, 2012
    The dryer is located on the side of the condenser. Facing the front of the vehicle it is the vertical tube on the left.
    Here's a photo album to browse, and you can determine if you are DIY capable replacing the compressor, dryer, and expansion valve (if needed).
    You will need to remove & store the refrigerant. Visit your local auto AC repair shop to capture the refrigerant, and after replacing parts revisit the shop to have the refrigerant returned to the system. If the desiccant from the original dryer has escaped, or the compressor failed internally creating debris, it may be necessary to vacuum the system as well.
  9. Crimson
    Crimson New Member
    Jul 11, 2012
    10
    Appreciate the reply, i successfully replaced the compressor and drier. Fees great having AC on these 110 degree days :D
  10. LIGHTINMCQUEEN
    LIGHTINMCQUEEN New Member
    Jul 29, 2011
    I picked up a compressor from Omega Compressors. They have brand new OEM, after market and rebuilt ones. I paid $245 for mine.
