Brakes Wheels 1st Gen Tires Aerodynamic 18" wheels?
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by HALL N S, Oct 18, 2010.
  1. HALL N S
    HALL N S New Member
    I need a source for some tall, narrow,18" aerodynamic wheels, in the MINI 4/100 bolt pattern.
    I assume they will be the typical steel wheel and ultimately have the flat aluminum disc wheel cover, but do want to consider "weight". and, as narrow as possible for less wind resistance....next search: "tall, narrow, hard tires" !
    Open to other suggestions.
    thanks,
  2. istara
    istara New Member
    May 21, 2009
    90
    Tucson, AZ
    I can understand light weight and narrow, for various reasons, but if you don't mind my asking, why do they need to be 18s?
  3. Rally
    Rally New Member
    50
    Ohio
    The largest steel wheels you'll find for the MINI will be 16". No one makes a 17 or 18 inch steel wheel in 4x100....I've looked hard.
    If you're doing this for hyper-mileage reasons, I would think the weight distribution on the 18's would negate most of the benefits. I could be wrong as my hyper-miling knowledge is limited at best.
  4. BThayer23
    Sounds like you're looking for a super fuel efficient wheel and tire combo. Might be better to look at 15's, as you can get some narrow tires on there like 185 section. Not sure what size Prius wheels are, but I think they're around 15's, so you could get some low rolling resistance tires, too. You're gonna be hard pressed to find an 18" wheel less than 7" wide, where plenty of 15's come in 6.5" width.
  5. ScottinBend
    Or a speed record and wants to fill the wheel wells.........?
