1st Gen R53 Cooper S After Gaskets, Seal & O-ring Swap, Oil Pan Still Leaks...Dayummm!!!
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by minsanity, Jun 11, 2016.
  1. minsanity
    minsanity Well-Known Member
    Sep 11, 2009
    581
    352
    Did my 55k maintenance a month ago.
    -Oil change 5w-30
    -Fumoto valve
    -Oil Filter housing triangle gasket
    11 42 7 509 211
    -Crank Position Sensor Blue O-Ring
    -Crank Shaft Seal Oil Seal...had to pull the ATI only to see a dry seal...
    -Oil Pan Gasket
    -Valve cover gasket
    Followed tightening sequence & torque...
    Now, I still get a drip every 3days or so on the lowest & rearmost bolt on the timing chain cover. Moisture follows thru the oil pan gasket joint & drips down the 1 oil pan bolt under the oil filter housing. No sign of any oil coming from up the block.
    My OCD has been whispering to go back digging, but sound tech minds have been telling me to leave it alone...
    Your thoughts, guys? You think I messed the new oil pan gasket? Kinda frustrating to go thru service mode & still have a slow drip.:(
  2. ZippyNH
    I'd say a mini that does not leak is a MINI without oil!!
    A tiny drip...one drip every 3 days...I'd not even stress it...it's not going to hurt anything until it get LOTS worse.
    That may never happen.....
  3. minsanity
    Sep 11, 2009
    581
    352
    Thanks, Zip, that's what everyone says. Just bummed me to go thru all that & still get drips.....not as bad as before though. Now, it's from that lone corner by the timing chain cover.
  4. fishmonger
    fishmonger Well-Known Member
    May 13, 2015
    984
    769
    Madison, WI
    If you decide that the drops must stop, you could use a UV die leak detector kit to hunt down the source of the problem.
  5. Sig
    Sig Member
    Jun 5, 2016
    136
    It's not leaking, it's just marking it's territory :wink:
  6. 00Mini
    2,259
    I hate leaks but one drip every third day is something I could live with.
  7. minsanity
    Sep 11, 2009
    581
    352
    Yeah, but getting under using a Rhino ramp, you just cant see much.:(
    Haha...long domesticated & housebroken...
    Incontinence might be the apt diagnosis.:)
  8. minsanity
    Sep 11, 2009
    581
    352
    Anyone here ever had to replace their timing chain cover gasket due to leaks? I'm still hopeful I dint mess up my oil pan gasket.
  9. minsanity
    Sep 11, 2009
    581
    352
    Good thing I've fumoto...realized I've overfilled oil. Got under & extracted a lil more than half a quart.
    The leak was slow, but constant at rest. I'm guessing the oil level is a bit above the sump gasket line...
    Can any1 confirm overfilling can cause this sump or timing chain cover gaskets to leak?
    Thanks.
  10. minsanity
    Sep 11, 2009
    581
    352
    Update:
    Timing chain cover still leaks at its rear-facing lowest point as some oil stays there at rest due to engine tilt. This was confirmed by the Great Maestro, Khuevo....
    Now, time to leave a cardboard by the garage floor. This shall be tackled on the next oil change.
  11. MCS02
    6,315
    Don't listen to them! Now its one drip but just think how oil is getting all over the motor. In 5 years or so it will be a mess!!!! as you sit reading this post oil is slowly getting EVERYWHEREyes everywhere!
    I would pull the engine and find it!!:biggrin5:
    Ok, I would leave it alone and just clean it with a little simple green every now and agin. Of course I use to own a Alfa. With Alfa's if the puddle in the morning is less then a foot your good to go.
  12. minsanity
    Sep 11, 2009
    581
    352
    Hahaha...after seeing the steps to replace the timing chain cover gasket....the cardboard by the floor & your simple green might be the best option.....
    ....for now.:D
