2nd Gen R56 Cooper S Alignment issues...How does yours run?
Discussion in '2nd Generation: 2007+ R55 through R61' started by Syberwop, May 2, 2011.
  1. Syberwop
    Syberwop New Member
    May 2, 2011
    My Cooper S is a 2007. I got it a little less than a year ago. No crash history, and I've not hit any curbs. Potholes, once or twice, but really nothing significant.
    When I got the car, it pulled to the right, but I took it to the dealer to have them check it out (I got it at CarMax) they said everything was running fine and that the Cooper S tends to pull to the right because of the turbo.
    Flash foward 9 months and the car is in the shop needing 2 new front tires because they're worn down almost to the rim. I had the tires replaced and an alignment done and the car is STILL pulling to the right (it's fairly significant, after about 2 seconds it will dart across two lanes).
    Does anyone have a similar experience? I don't know if the dealer is just screwing with me at this point or if the S's really do pull to the right. Or is this a sign of some greater trouble?
    I'm a chick without a lot of experience when it comes to mechanics...please give me your advice so I don't look like an idiot next time I go into the shop!
    Thanks!
    1. Take it to another shop!
    2. Get a print out of the readings and share them with us please. We can help guide you with that info.
    How are the tires worn? Inside, outside? down the middle? Can you post a picture of a worn tire please.
    Welcome to the site too, thanks for being a member.
  3. Metalman
    The reference of "Pulling To The Right" as an inherent trait of the Cooper S has more to do with "Torque Steer" when you are mashing the go pedal hard. With proper tire inflation and proper alignment the MINI should not pull to the right (or left for that matter) under normal conditions.
    Since you bought it from CarMax as a used vehicle, the previous owner may not have been as careful with the pot holes. The best thing to do is to take it to an alignment shop that is familiar with MINI's.
  4. Mr. Jim
    Hello and welcome! What Nathan and Metalman said :Thumbsup:
  5. Redbeard
    1,636
    398
    Glorified spreadsheet jockey.
    When it pulls to the right was it under acceleration (pushing the gas pedal down) or just cruising (no gas pedal) in a straight line?
    Rotate your tires every 5-7k miles. MINIs wear tires front heavy and if you rotate them you will find yourself replacing them less often and 4 at a time versus 2.
    I'll be honest. I've dealt A LOT wih Carmax, and while I'm sure everyone else here has some epic negative experience with them, I haven't. They have been really great for me in both sales and service. I doubt they are "screwing" with you. My guess is that there may be an issue with what they think the specs should be and what they actually should be. I'd follow up on what Nathan said and upload the alignment print-out so we can see if something is off.
  6. Justa Jim
    Welcome aboard. Follow the advice and this place can help you out. :Thumbsup:
  7. Syberwop
    Syberwop New Member
    May 2, 2011
    Thank you all, this is great information. I've been dealing only with the dealership because it's under warranty (of course the tires and alignment aren't), and I figured they would do the best work.
    I'm taking it back to the service manager and I will get a printout of the specs...I hate to sound so naive, but what should the alignment be? I've read between .37 and .34. Does that sound right?
  8. goaljnky
    3,105
    394
    Those are just your caster settings, I believe and are not adjustable. You should be primarily concerned with your camber and toe. Not sure what the factory settings for those would be for MIK2 cars.
  9. Mr. Jim
    Most dealers farm out their alignment work and if it wasn't a MINI dealer they probably use the cheapest place. You need to find a real good alignment shop since your paying anyway. If it's pulling it's off.
  10. grodenglaive
    grodenglaive New Member
    Apr 3, 2010
    313
    68
    Ottawa, Ontario
    If it always pulls in the same direction while cruising, that usually indicates a bad wheel bearing or a dragging brake on that side. Suspension dammage may also be a possibility.
    The wheel alignment (especially the toe in) will certainly affect how the tires wear though and if they're wearing really unevenly, the toe must be way off. I wonder if the previous owner hit a curb hard enough to bend a tierod or something.
  11. Friskie
    Friskie Well-Known Member
    Jul 20, 2009
    1,650
    1,333
    Highly motivated retiree
    In the here and now, for now.
    When you get it properly alligned, it should track like it was on rails. At least mine does as do all Indians walk in single file. I know because the one that I saw, did. Find the big dog tire, wheel and allignment shop. They will have the specs, equipment and know-how to do it right, smoke out any possible problems and have you back on the road with the silly grin that you deserve.
  12. alf2all
    alf2all New Member
    Jul 24, 2012
    pulling minis like untrained dogs
    It appears that the mini is a very fickle beast. Mine as well has a tendency to go off alignment very easily. Once again my front wheels are cupping, and if anyone out there knows for sure what the toe (not tow) specs are supposed to be, that would be great.
    thanks
  13. Redbeard
    1,636
    398
    That is a sign of suspension damage or poorly re-assembled suspension. I have 64,000+ miles with autocrosses and track days and I've never needed an alignment.
    How many miles on your MINI? I agree with Redbeard something is worn out.
  15. davavd
    davavd Club Coordinator
    6
    Architect
    Covington, La
    Front control arm bushings were the first thing to go on mine. Struts were next; I think that's when I saw cupping on my tires.
  16. Redbeard
    1,636
    398
    This is for 2nd Gen MINIs.
  17. r34king
    r34king Member
    Aug 18, 2011
    71
    34
    Auto Tech NTB Capital BLVD
    The control arm bushings can still go bad. I'd look at those first then the motor mounts. After having an alignment done properly
  18. davavd
    6
    Architect
    Covington, La
    Oops, missed that.
  19. DixonL2
    DixonL2 New Member
    274
    A bit north of the 'burgh, PA
    #19 DixonL2, Jul 26, 2012
    Also check REAR wheel alignment, it's fairly common for them to come from the factory with some weird rear toe settings. This is adjustable by moving the trailing arm mount to the chassis (loosen three bolts, adjust (holes are slotted), drop to ground, roll out, re-check alignment)
    (above paragraph edited thanks to my great friend Jason, who posted below AND who checked and corrected this on MY car!)
    Also check and re-check tire pressure, even a 1/2 psi difference can result in a pull, as can a "tire pull", where a minor difference in tire construction (even between tires of the same make/model) can result in a "pull". Rotate, change position of tire on car, re-check. Both a tire-pressure difference and a "tire pull" can show up as either a consistent pull, or as a pull only on acceleration/braking.
  20. jasonsmf
    jasonsmf Active Member
    111
    27
    engineer
    Elyria, Ohio
