Are the door seals covered in the warranty?
Discussion in 'MINI' started by buttonbag, May 28, 2014.
  1. buttonbag
    buttonbag Active Member
    Apr 5, 2013
    178
    133
    As the title says, are the door seals covered under the 10 years, 100,000 factory warranty?
  2. Metalman
    Did you get the extended warranty?
    Are your seals a little crusty on the surface? Aren't sealing too well.....
  3. Zapski
    The warranty covered my mirror caps when they faded. Sooooo... worth a shot I'd say.
  4. buttonbag
    Apr 5, 2013
    178
    133
    Every time I get a wash, soap suds get in the door jamb.
  5. ZippyNH
    Don't think anything but RUST is covered by the 10 year (was made a 10 year warrenty in 2005+)...
    There are a couple other warranties on a few items....but I don't think any cover any trim or other rubber items like weather stripping....heck having the rubber "beltline" dry rot and chip is a common issue on the cabriolets.....
  6. jiminni
    jiminni Well-Known Member
    262
    Ca.
    10 year 100,000 factory warranty? Maybe on the emissions, but not everything else?
  7. jiminni
    262
    Ca.
    No kidding! It's ridicules how fast that piece of trim goes bad :mad5:
  8. buttonbag
    Apr 5, 2013
    178
    133
    I was hoping they were. I ask because one, I'm OCD and two, I looked up how much a door seal costs. $230 for one?? :(
  9. rkw
    rkw Well-Known Member
    443
    Except for rust, the basic warranty is 4 years, 50K miles. There have been only a few items involving safety or emissions where MINI extended the warranty, to avoid doing a full blown recall.
  10. ZippyNH
    Cars age....
    Warranties end....
    And rather than car payments....you get to buy carparts!!
    Still cheaper than a new car though....
    But some items....you can learn to live with...replacing each and every imperfect item on an older car can get $$$$…......
  11. Minidave
    4,594
    Soapsuds on the door sill plates and jambs not caused by bad seals, if you look you'll notice the seal is inboard of the sill plate, it's supposed to be able to drain water away there.
    Take a towel and just wipe it down.....
    The original factory warranty on all MINIs is 4 years or 50K, whichever comes first. The only way you'd have a 10 year/100K is if you bought an extended warranty - which is not issued by the factory but by some third party company. Whether they'd cover them is up to the terms of that warranty contract.
  12. BlimeyCabrio
    ... and if "soap suds get in the door jamb" means that the suds actually come through the door jam to the inside of the seal... it's still not a "problem" if you're in a high pressure carwash (e.g. brushless).
    The seals are meant to keep out rain and wind... NOT a pressure washer aimed directly at them. If a seal that leaked in a pressure carwash was a defect, every cabrio owner would have returned their car when new.
    Now, if it's a brush-type wash, why the heck are you swirling your paint!?!?! :D
  13. Dave.0
    Also hand wash your car and don't use the drive thru washes because they are scratch machines.
  14. Metalman
    I get soap on my door jambs all the time.... Doesn't mean my door seals are bad..... The doors seals are inboard of the jambs.... The seals would be bad if soapy water was getting into the cabin....
  15. buttonbag
    Apr 5, 2013
    178
    133
    Actually, I found out that mine is still under 10year/100,000 mile warranty. I have an '05 and the dealer is fixing some rust I have on the hatch door at no cost to me. I found out that the rust is covered after talking to Xiek at the dragon. This is my first year of owning a MINI and luckily, it's just under 100k.
  16. rkw
    443
