Engine Drivetrain 1st Gen Cooper S ATI crank pulley
Discussion in 'Tuning and Performance' started by MCS02, Dec 17, 2016.
  1. MCS02
    Does anyone know how to remove a ATI crank pulley?
    There are three holes I thought I could screw the puller into but they are very small and I do not believe they are threaded. It seems like I had read somewhere that you should not remove the three bolts that are in it to use with the puller. I can't find anything ether way. Anyway if someone has done it that would be helpful.
    Ok, I will ask, you are removing it why?
  3. MCS02
    New seal
  4. DneprDave
    For seals you sneak up on them & then club them into submission. :ihih:
    Lee I'd call Helix or Detroit Tuned & ask them, maybe even a call to ATI. For what that ATI costs you don't want to de$troy it.
  6. bigjas
    bigjas Member
    Sep 3, 2016
    195
    Colorado Springs, CO
    From page 4 of my installation instructions:
    1. Remove at least (3) three bolt from the damper on an equal pattern for use with damper installer/removal tool.
    2. Refer to damper install/removal tool instructions to remove damper.
  7. MCS02
    Ok thanks.
  8. M1N1
    M1N1 Well-Known Member
    Jan 5, 2014
    726
    329
    Tool and Die Maker
    NW Ohio
    Qoute from ATI site; "For best results, use a damper installation tool when you install or remove your damper".
    For what it's worth, I also found this on the ATI site. Installation kit is part number 918999.
    But I'm guessing that you've already been thru this.
