ATI Super Damper
Discussion in 'Engine & Drivetrain' started by k-huevo, Aug 8, 2009.
  1. Tüls
    Tüls New Member
    Apr 3, 2009
    438
    12
    The sky
    K-huevo, did you happen to talk to them about the higher RPM factor? I know most dont go much above 7k maybe 7300 ish for some. I see the chart shows 8k But I am wondering about the 8-10k RPM ranges... :D
  2. mini_racer
    mini_racer Well-Known Member
    Engr Manager
    Thanks for the additional info K, I must have missed that chart from their website, it is very helpful. Just for kicks it would be nice to also see the twist for a non-damped pulley, you would have to blow out the scale on the y-axis though. :lol: It has got to be much worse.
  3. k-huevo
    k-huevo Club Coordinator
    159
    Pipe Creek, Texas
    I spoke with ATI this morning about a few things including rpm range; no worries for the Super Damper, it's up to the task.
    I visited a respected engine machine shop today for engine post mortem evaluations; the ATI Super Damper gets very high marks especially for overhead cam & chain motors.
  4. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #24 Nitrominis, Aug 10, 2009
  5. k-huevo
    159
    Pipe Creek, Texas
    I installed the ATI Super Damper on my MCS.
    Cool profile, too bad I didn’t line up the timing marks.
  6. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    :strokes beard:
  7. k-huevo
    159
    Pipe Creek, Texas
    #27 k-huevo, Aug 21, 2009
    The allen head bolt ATI provides with the damper serves as crankshaft thread protector and platform when using a conventional bolt grip puller, plus it's a convenient installation tool. The OEM installer with bearing reduces effort, but the bolt and washer actually work.
  8. mini_racer
    Engr Manager
    Looks like a fine unit K. Anything to report on the operation? Obviously, installation went rather smoothly.
  9. k-huevo
    159
    Pipe Creek, Texas
    I don't feel buzz through the steering wheel anymore.
    Installation was simple, removing my late model OEM pulley was not.
  10. nabeshin
    nabeshin New Member
    Jun 8, 2009
    409
    Lincoln, NE
    So did you need some kind of special tool to get the oem crank pulley off?
    Installation was as easy as tightening the center bolt?
    I'm going to have to put off getting a new crank pulley until something goes wrong with mine. (cost issue)
  11. k-huevo
    159
    Pipe Creek, Texas
    Normally it's not difficult removing the OEM pulley, early or late mode, and lightened aftermarket pulleys are a breeze pull off. My late model OE was a very tight install to begin with; my installer tool bearing froze during installation four years ago, so not the average fitment. Success came after welding nuts to the pulley, so I could use larger bolts to pull with on a robust bolt grip puller, and firm hammer strikes to the extractor bolt while under tension.
  12. nazrin
    nazrin New Member
    Jul 20, 2009
  13. Ryephile
    Ryephile New Member
    Apr 9, 2009
    299
    122
    Yes!
    Metro Detroit
    ***bummed about the larger pulley size***
  14. mini_racer
    Engr Manager
    Why, it is just 1% larger? What is the big deal?
  15. Ryephile
    Ryephile New Member
    Apr 9, 2009
    299
    122
    Yes!
    Metro Detroit
    IIRC, they made it a whiff larger to accommodate the generic size damper hub.
  16. mini_racer
    Engr Manager
    Yes, it is understood why it was made a whiff larger, but why are you bummed? Why does that whiff make you bummed?
  17. Ryephile
    Ryephile New Member
    Apr 9, 2009
    299
    122
    Yes!
    Metro Detroit
    There's no good reason to make the alternator, a/c compressor, or supercharger [w/15%] spin any faster than they already do. The minutely increased angular momentum also annoys the OCD-side of me.
    Ok, they're not very good reasons. I'll just sit here with my box of Kleenex 'til I get over it. :eek:
  18. mini_racer
    Engr Manager
    There are many things to get all OCD about, I have a long list myself. This just does not seem to be on my list.
    It's gonna be OK, just relax and breath deeply.
    More seriously, you do have a point about the revs, I think my higher rev limiter and track days were instrumental in sending one AC compressor to an early grave, and I would guess the alternator is not too happy with its similar treatment as well.
    At least this 1% comes with more boost, I know, I know it also comes with more heat and more SC wear out.
    Still.......this looks like a great damper replacement.
  19. nazrin
    nazrin New Member
    Jul 20, 2009
    hmmm...might wanna try this damper with a 13% pulley and a 17% pulley...see how dats like...
  20. spdfreak
    spdfreak New Member
    Aug 1, 2009
    Can anyone comment on how well this dampener plays with a lightened flywheel?
