ATI Super Damper
Discussion in 'Engine & Drivetrain' started by k-huevo, Aug 8, 2009.
  1. Way Motor Works
    Way Motor Works New Member
    206
    MINI Tuner
    Atlanta
    The one listed as OEM size isn't quite 1% overdrive. To be exact it is 0.8% overdrive, per ATI's measurement. Just some FYI for those conserned about the size.
    If you ordered it today, I haven't seen the order cause I have em ready to ship.
  2. mini_racer
    mini_racer Well-Known Member
    Engr Manager
    I purchased from a non MA sponsoring off forum vendor for some personal reasons. I am sure Werkin or Way can provide superior service and support on this product.
  3. mini_racer
    Engr Manager
    Well, I am disappointed to report that the ATI Super Damper weighs at a hefty 90 oz, that is just 2 oz lighter than the OEM face lift damper for the 1st gen.
    This is 5.625 lbs....... A far cry from the 3.6 lbs listed above and on the ATI website as the weight of this damper!
    So, while this is still a good product, don't get it if your only reason is to get something lighter than the face lift damper!
  4. ScottinBend
    You sure you got the right one?
  5. mini_racer
    Engr Manager
    On the ATI website there is only one listed. This is their 'standard' OEM replacement, the 5.5 inch diameter model (i.e. 1% oversized). ATI model # 917992
    Yep, it is a heavy mofo, just like OEM. :(
  6. ScottinBend
    I just meant did you check to make sure they actually sent the right one. Part number on the product is correct.
    Too bad if the info on the site is wrong, but it is still a great option for a replacement.
  7. mini_racer
    Engr Manager
    Yeah, the enclosed paperwork is correct, the box has the proper part number, and the hub is also stamped with the proper number.
    So yeah, it is very disappointing about that spec discrepency, but sure it is still an excellent OEM replacement.
    I just HATE specification surprises, if I did not receive what was specified....... Then I did not get what I paid for.
    So, has anyone else out there put one of these on a scale? Any supporting or refuting data out there?
    Keith? Way?
  8. k-huevo
    k-huevo Club Coordinator
    159
    Pipe Creek, Texas
    I weighed the three model dampers again for the umpteenth time.
    ATI Super Damper 5lb 9oz
    Late model damper 5lb 18oz
    Early model damper 7lb 4oz
    Looked through my posts elsewhere and found this mention Mini Torque - View Single Post - ATI Super Damper Crank Pulley - post 92354
    I'm sorry if you feel mislead; I can see where you might have thought I supported 3.6lbs for the ATI when I deferred to Pharaoh. Having read through a multitude of threads researching this point, I also see 3.6lb mentioned many times; normally I have no qualms about correcting others.:eek: In fact when I corrected a vendor's weight quote on the sewing site, that post along with others of mine were removed.
  9. mini_racer
    Engr Manager
    #89 mini_racer, May 20, 2010
    The issue starts with ATI as their website specifies a total weight of 3.6lbs or rather 3lb 9.6oz
    My measurements yield:
    ATI Super Damper 5lbs 10oz
    Late Model OEM Damper 5lbs 12oz
    So, the ATI spec of 3.6lbs is not even remotely close to the reality of an actual measured value of 5.6lbs.
    I realize, it is not your spec K. However, I did take away the impression that you were in agreement with the 3.6lbs stated specification.
    The bottom line is that this is still an excellent replacement for the OEM crank damper, but the weight saving from the late model damper is not statistically significant. For all intents and purposes, it weighs the same as the late model OEM damper.
    Oh and speaking of correcting others, you typed 5lb 18oz above, but I think you meant 5lb 13oz as that is consistent with your Mini Torque post.
  10. k-huevo
    159
    Pipe Creek, Texas
    #90 k-huevo, May 20, 2010
    Good catch, I've lots of distractions this evening.
  11. mini_racer
    Engr Manager
    At first ATI wanted to argue with me. ATI is definitely not the best when it comes to customer service. Then finally it was admitted that their website was WRONG, flat wrong. Their website will eventually be corrected.
    So, expect your ATI Super Damper to weigh 5.625lbs, not the 3.6lbs specified on the website!
  12. Metalman
    Big mistake to argue with any customer when it's proven that the company is wrong.:nonod: The best course of action is to apologize, make the correction and move on. I can't understand why a company would want to damage their reputation by doing something like that?:mad2: Cool heads need to prevail on both sides of the fence.:yesnod:
    Good customer service is golden.
  13. mini_racer
    Engr Manager
    What I received from ATI:
    - no apology
    - no commitment on issue resolution
    - no thanks for identifying their documentation error
    - a bad attitude and defensiveness
    - a listing of many of the dampers they did spec properly on their website, as if that matters to me
    Having experience running customer support operations for a large global corporation provides a little background in assessing 'good' from 'not so good' customer service. I would characterize what I experienced from ATI as 'bad'. Keeping a cool head is definitely critical.
    It is a good product, but be aware that it weighs 5.625 lbs, not the 3.6 lbs as listed on the website. Also, hope that you never have to call them with an issue, as you will be sorry you did.
    It is not likely that any of you would ever have cause to communicate directly with the manufacturer anyway. However, a little insurance against such an encounter would be to just purchase from one of our sponsors like Werkin. So in the unlikely event that there would be a need to contact ATI......make Keith do it. :D
  14. mini_racer
    Engr Manager
    Well surprise surprise, I just looked and ATI has already amended their website.
    Take a look:
    ATI - Super Dampers® for Mini Cooper Engines
    It is still wrong though as the weight is spec'd as 6 lbs, but as stated above it actually weighs 5.625 lbs. So now it is wrong on the high side, and so it looks like it weighs more than the OEM damper, which it really does not! :crazy:
    Keith, this is a great opportunity for you to call ATI, and inform that their inaccurate website specification is hurting your sales of this product as your potential customers will not purchase something that is heavier than the OEM damper. :eek:ut:
  15. Metalman
    Maybe they are using a really bad / damaged scale that is fluctuating wildly and they haven't figured it out yet?:eek:ut:
  16. ColinGreene
    ColinGreene Well-Known Member
    438
    293
    Orange county Ca
    I guess I dont understand the need for all the talk about the weight if Kevin weighed it and established the weight for us.
    Also 90% of the reason to buy this is for its damping ability not the light weight.
    If it was infact for the light weight we could all buy lightened crank pulleys... right?
  17. mini_racer
    Engr Manager
    #97 mini_racer, Jun 17, 2010
    1. Not sure who Kevin might be, but Keith is certainly a part of this thread. I do not require anyone to weigh something for me. So, I made my own measurements and discovered the ATI error.
    2. The issue with this product was that it did not weigh as specified. As such it was effectively 'out of spec', and so a purchase made expecting specification conformity resulted in disappointment.
    3. Lighter is always quicker. Weight is certainly a factor, as is damping ability.
    4. Many in fact do select a lightened/undamped pulley as weight is their primary selection criteria. For me, I wanted superior damping, and superior weight. This ATI Super Damper was erroneously specified to deliver exactly that.
  18. ColinGreene
    438
    293
    Orange county Ca
    oh boy your one of those guys,:rolleyes:
    Sorry I ment Keith not Kevin.
  19. Tim_
    Tim_ New Member
    Sep 8, 2011
    The weight listed was originally for the "Shell Assembly" - internal inertia weight and outer shell - not including the hub.
    The shell assembly (3.6lbs) + the crankshaft hub (2.6lbs (average)) = ~6.2 lbs
  20. k-huevo
    159
    Pipe Creek, Texas
    ATI Super Damper Titanium Bolts
    Lightweight Titanium Bolt Kits for ATI Dampers are now available.
    The main advantages as I see it are, lightweight low profile 3/8-16x1 replacements for the Torx E bolt heads, and corrosion resistance for the face bolts. The original tall Torx E bolt heads can abrade brake duct tubing in some close fitting installations.
    When distancing a duct from the damper, the wheel well liner is pushed outward, which can cause contact with wide tires at full lock.
    I don't know how much shorter the Titanium bolt heads are at this time. Retail $35.95 Part# 950200T
