Autoflash by MADNESS
Discussion in 'Sponsor Messages' started by MADNESS Autoworks, Jun 29, 2016.
  1. MADNESS Autoworks
    67
    Introducing the Autoflash by MADNESS. Available for all models of the MINI platform
    Increase performance with faster gear shifts on your MINI with the AutoFlash by MADNESS!
    The MADNESS AutoFlash relies on updating the maps of the TCU to allow the gearbox to improve shift times and bypass the torque limiter.
    Often times vehicle manufactures will limit the full potential of a vehicle to compensate for all levels of drivers and maintenance, or because the manufacturer knows that in 18 months they will be releasing a more powerful version of that vehicle and can adjust the limiters to allow for this power increase.
    So, the idea of the AutoFlash is to not only increase shift speed but to increase torque limitations throughout the gearing (except for 1st and reverse gears as we leave these at factory spec for safety) which in turn changes the speed of a shift.
    The AutoFlash has been thoroughly tested both on the road and the track and we are sure you will agree that the shift and positive feel of the engine after the flash makes for a superb upgrade.
    Due to the fact that the AutoFlash is adjusting the shift points of the gearbox, the difference is more noticeable on automatic transmission models, but it will still make a nice difference on manual transmission models as well.
    Features:
    Plugs directly into the OBDII port
    Installs the software in 30-90 seconds
    Uploads new maps to the engine ECU and gearbox TCU
    Will not affect any Performance ECU Flash/ Piggy Back Engine Module
    Will not trigger the ECU Flash counter and is not dealer traceable
    Completely reversible
    Increase shifts by up to 24%
    Bypass throttle limitations
    Tested on road and track
    Increase longevity of the clutch system
    About the MADNESS AutoFlash:
    AutoFlash can be used with any tuning box and other engine hardware modifications without issues.
    The AutoFlash maps install within 30-90 seconds and it will not change the ECU flash counter or file size which could alert the manufacturer, this flash is undetectable.
    If you ever take your car to a dealer for service or software update and they overwrite the AutoFlash, simply re-install it just as you did during the first installation. You can do this as many times as needed to your vehicle. Keep in mind that the AutoFlash will lock on to your cars VIN Number on first use and cannot work on any other vehicle after you sync it with your car.
    Please Note: The MADNESS AutoFlash is individually programmed for each specific vehicle at the time of ordering. Please allow 10-14 days for delivery.
    Direct Product Link: http://minimayhem.com/shop/index.php?route=product/search&keyword=autoflash&category_id=0
  2. MADNESS Autoworks
    67
    If you have any questions about this product, please don't hesitate to ask!
  3. MADNESS Autoworks
    67
    Improve your MINI's performance with ease! The AutoFlash installs the software in 30-90 seconds! As always, if you have any questions about the product, please do not hesitate to reach out to us!
  4. MADNESS Autoworks
    67
    Want to learn more about the AutoFlash? Watch this video as we talk about the AutoFlash in detail!
    [ame="http://www.youtube.com/watch?v=WmlQWa9bkIY"]Gearbox Tuning Module - AutoFlash by MADNESS - YouTube[/ame]
