Entertainment Electronics 1st Gen Aux input sound level
Discussion in 'Tuning and Performance' started by ScottinBend, Apr 19, 2015.
  1. ScottinBend
    Ok.....finally got my aux input installed and hooked up the phone. Surprise, no sound. Checked the aux volume number and put it on 5. Still no sound.
    Hmmm.........bad cable? Nope, just really low/shitty output from the phone. Have to turn up the HU to 11 just to get it loud enough to enjoy
    Anyone else have this problem?
  2. ScottinBend
    Anyone......Buehler, Buehler.....
  3. BlimeyCabrio
    Mine has always worked fine... zero help.
  4. MCS02
    Is the volume up on the phone?
  5. Dave.0
    Take phone off of Vibrate?
  6. Zapski
  7. cct1
    Maybe all those ringing sleigh bells caused permanent high-pitched sensorineural hearing loss?
  8. Dave.0
    Santa says ...... WHAT ?
  9. ScottinBend
    Frikkin' clown college around here...........:p
    Yea, phone volume is turned up and I can listen to the tunes no problem with ear phones.
    Maybe I should check and see if there is a way to increase the sound level of the mp3's and reload them........
  10. BlimeyCabrio
    something just doesn't sound right here. If you can get a good enough signal out for headphones, then the aux should work.
    Is the iPhone in a case or bumper? Is the audio cable plugging in completely?
    Do you have another car with aux in that you can test it on, and another cable, to completely eliminate both those as the culprit?
    Do you have another iphone (or a friend with one) who can plug it in to your aux in with the same cable, to test?
    What generation / model iPhone?
  11. Zapski
  12. Kenny kustom
    Kenny kustom New Member
    Jan 24, 2015
    297
    178
    This. Make sure the cable is seated all the way in.
  13. MCS02
    Did you press play?:D
  14. Dave.0
    Is the key in the car with it in the on position with the radio on? :lol:
  15. ScottinBend
    :p:p:p
    The volume from the ear phones is loud enough for me, but the level may not be enough for the car.......
    I am using the oem aux input with the radio set to 5 and the cable is fully seated in the plug, both ends in fact. :D
  16. Dave.0
    Is that cable from oh I don't know......ALTA. :lol:
  17. ScottinBend
    :rolleyes:
    :lol:
  18. Zapski
    So just a single cable with a headphone jack on both ends? That sounds like a grounding issue then. The cable I linked above should fix that.
    :crazy: HEY LOOK! I ACTUALLY TRIED TO HELP! :crazy:
  19. rkw
    rkw Well-Known Member
    443
    How high do you turn up the volume on the phone? What phone is it? From what you've said, I'd say it is a bad cable.
  20. cct1
    Try another device in the aux/in. Mine is set to 3 and is plenty loud.
