Exterior 2nd Gen Belt Line Black Out Tape
Discussion in 'Tuning and Performance' started by Justa Jim, Jun 18, 2010.
  1. BoCRon
    BoCRon Active Member
    Mar 27, 2011
    135
    37
    Milton, GA USA
    Thanks, this is on my list for this weekend. I have had my new '11 MCS and so far the only thing I've gotten modded is the stubby antennae and blacking out the gas cap.
    Annette
  2. ScottinBend
    I quick update from me.....I pulled off the old tape as it finally was getting really ragged looking and actually sprayed the beltline with Plastidip black and boy does it look better than the tape. And so far it has stood up to the elements better. Took a bit more time to do as you have to mask the car to paint it, but you will love the results.
    I even did the rain gutter around the roof as well and it really looks good. The rain gutter was getting really faded out and hard to keep looking black. But with a couple of coats of the Plastidip it looked better than original.
    Only real tip you need is that you will need to score/cut the plastidip at the tape line as the plastidip is a rubber and it will tend to pull off the surface when you try and remove the masking tape.
  3. BoCRon
    Mar 27, 2011
    135
    37
    Milton, GA USA
    Thanks, I haven't tackled the beltline yet as the headlight trim took me most of the day. Octane Guy posted that you can use Black Wow on the plastidip, so that is a bonus!
    Annette
  4. Rixter
    Rixter Well-Known Member
    Jun 14, 2009
    1,230
    79
    Technology Architect
    North of the 49th
    Scott, how about a couple-o-pix? :popcorn:
  5. VYPUR
    VYPUR New Member
    Mar 27, 2011
    14
    Huntsville Alabama
    Yours is exactly how I want mine to look. Started with the windows this weekend. Your car looks GREAT!
  6. iwashmycar
    iwashmycar Active Member
    Jun 1, 2009
    881
    87
    architecture
    I've had the OutMotoring tape on mine since new. Been through a lot and still looks pretty good!
    I think I had just cut it 1/2" longer each piece (each side) and applied it. I then went back and took the clear piece off, and to finish Xacto'd the remaining.
  7. ScottinBend
    #27 ScottinBend, Apr 3, 2011
    I have taken some pic's but to tell the truth you can't really see anything from them. Only way to really see how it looks is to try it yourself. You can always easily remove the Plastidip after it dries. This is actually the reason I tried it in the first place.
    And one other advantage.....you can very easily touch up the Plastidip if it gets damaged.
  8. gmodder
    gmodder New Member
    Sep 25, 2010
    16
    Technician
    Willis,Texas
    whats the best way to get the tape off once you have it on for a few months..I need to redo mine cause it didnt turn out as good as I wanted..
  9. ScottinBend
    I used a heat gun on low and was VERY careful not to get the tape to hot as it would tear. You need to get it just hot enough to pull off, but not hot enough to start stretching it.
    Then you can use some solvent to get the left over adhesive off and prep it for the Plasti-dip! :D
  10. OutMotoring
    OutMotoring Club Coordinator
    69
  11. CHKMINI
    Thanks Aaron. I blacked out my '04 using the tape Outmotoring supplies and after 3 years and 106,000 miles it still looked good. My '09 has the same tape from Aaron, now on for 2 years and 58,000 miles and it too still looks good. The secret when installing it is not to stretch the tape. Use just enough tension to keep it straight and remove the outer clear protective film AFTER the tape has been installed for at least 8 hours.
    Mark
  12. BoCRon
    Mar 27, 2011
    135
    37
    Milton, GA USA
    Just started this. It took 30 minutes just to do the boot section. The hardest part was getting the clear top piece to come off. Then when I got it off, I was wondering why I bothered since the tape is glossy just like when the clear piece is on there. Also ended up with quite a few bubbles so I'm hoping those will work out with time.
    Annette
  13. CHKMINI
    Annette, you probably don't want to wait but someone will help you do this at the Dragon.
  14. Zeyk_Shade
    Zeyk_Shade Member
    Oct 14, 2010
    89
    I used #33 Black Electrical Tape, easy peasy.
  15. BoCRon
    Mar 27, 2011
    135
    37
    Milton, GA USA
    LOL, that is now my plan. I've put the remaining tape back in the box and will bring it with me to the Dragon. If I need to re-do the back, I'm pretty sure I can pick up some more tape there.
    Annette
  16. Rixter
    Jun 14, 2009
    1,230
    79
    North of the 49th
    How's that around the corners? Bit of puckering?
  17. Sideways
    Sideways New Member
    May 12, 2009
    539
    37
    Above the Border^^^
    Did the beltline black out last year around this time.
    The pics are from just before MTTS (hence the DENVER-OR-BUST sticker on the bumper)
  18. oldcracker
    oldcracker New Member
    Jun 10, 2009
    anyone have any close up shots of the ends?
