2nd Gen R56 Cooper S Bi Hex Spark Plug Socket for R56
Discussion in '2nd Generation: 2007+ R55 through R61' started by TGS91, Sep 15, 2010.
  1. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    Hit 60K and manual says I'm due for a new set of plugs
    Way gave me the heads up they came up with a special bi-hex spark plug that requires a 14mm bi-hex socket. The one that is in your socket set ain't gonna work.
    And because Mini, Citroen and Peugeot are the only cars using this, maybe more?, they are charging a arm and a leg for it. First look was $40-$80 for a freakin' socket.
    Best I could find 0890000004 Bi Hex Plug Socket - US Distributor of genuine BERU products - Kingsborne Wires Werks
    PS-If you don't have one get a lengthy extension cause those bad boys are set kinda deep in the engine block
    Got's to pay to play boys and girls :cryin:
  2. cal330ci
    cal330ci New Member
    Aug 30, 2010
    38
    Automotive Technician
    Vancouver BC
    I believe BMW 335s use the same socket. Mine is an AST and it was about $35cdn from Mac or Snap On.
    Pay to play is a good way of putting it.
  3. btwdriver
    btwdriver New Member
    Any 12 point 14mm socket will work. I have a craftsman that works just fine. You will likely need a set of needle nose pliers to pull out the plug once is is loose. They do make some fancy spark plug specific sockets if you so desire. I already had the socket on hand, so I never really bothered with anything else.
  4. Minidave
    You mean a deep well 12 pt socket, right?
    You can make the socket grip the plug by putting a small piece of electrical tape in the socket, just start it on the inside and wrap it around to the outside on one edge - it makes it just tight enough to grip the plug and hold onto it as you withdraw the socket from the well.
    If your socket's worn, you may need two peices - opposite each other.....
  5. btwdriver
    Yea, correct a deep well.
