BIGGER is BETTER!!! A FAQ on the Bosch 550cc injectors for R53
Discussion in 'Bytetronik Tuning Discussion- Archive only' started by mike@MynesTuned, Mar 11, 2010.
  1. minimark
    Sorry Mike but faq #6 & #7 do not answer my question at all....
    If you tune my car to the maximum output with everything running in range including the injectors (not maxing out) and you then put larger injectors ( nothing else) in it, and then tuned it again would you be able to get more power out of it; make more power than the previous tune?
  2. minimark
    Thought I would put the original post here for ease of reference.
  3. Mr. Jim
    Mark, it looks like you have answered your own question. Common sense would show that if everything is maxed, but within proper operating conditions at the entire range, then why would you even consider larger injectors? It seems as the larger injectors might have to be scaled down to achieve the previous "sweet" tune.
    Only if the original injectors couldn't achieve the "perfect" tune would you need to use the larger injectors.
    Does that make sense?
  4. N2MINI
    N2MINI MINI of the Month
    Dec 4, 2009
    3,349
    575
    Sign Maker
    Well said Mr. Jim
    I believe he was just TRYING to get Mike to say that.. Admitting that just by adding the 550's you will not necessary gain power.. Only if you actully need the extra cc's would you gain HP.. They are pushing the 550's in a BIGGER IS BETTER way and you may not need them... The plus side for them selling them is you will HAVE to have a tune for the car to run right.. So by selling the 550's they also get a tune out of it as well...
    If you need them great, if not your probably good with what you have already..
  5. cct1
    If Myne's came out with a 100% bulletproof package that gave 250 WHP, the usual suspects would bash it.
    It makes perfect sense to go with the 550's, IF you're maxing out a smaller sized injector. I remember way back when, when Jan used to say all you need is 440's, that 550's were overkill. That has changed. It's not a knock on Jan, he's adapted.
    This is such an easy concept, the arguments posted here are going beyond the esoteric. There's a ton of snow where I live. Given the choice of a snow blower or plow, which should I choose? I could use a snowblower, but it's gonna stress it out to the point where it's probably going to malfunction at some point. Guess the plow would be better. When there isn't much snow, the plow is overkill, the snowblower works just fine.
    There is a whole other area to this that hasn't been touched on: you're probably best off putting in the injectors that your tuner has the most experience with tuning, and is most comfortable with. So if you're getting a Myne's tune, do the 550's and be done with it. It's not a price issue, it's not like they're recommending something that's going to be more expensive than 380's or 440's, so what exactly are we arguing about?
    If you're going with another tuner, 380's or 440's may be just fine for your application. Each car is different, and depending on who is tuning, and the power your car is laying down, a smaller injector may be just fine, especially if that given tuner is most comfortable scaling that particular injector, right?
    IMHO (and I have never worked with or bought anything from Myne's, although I do respect what they do, they're just too damned far away), you got the usual naysayers that are going to take issue with Myne's no matter they do, just as you have the usual naysayers that will take issue with RMW no matter what they do. It's predictable, somewhat saddening, and entirely boring. Why does this have to get so contentious over something that's relatively so minor?
  6. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    Not to open a Pandora's box lol but RC Fuel Injection would say differently about the use of larger injectors. In the past I have used some RC ??0cc saturated injectors before the thought of 550cc in the MINI with no real noticeable difference over other suppliers of similar size. MY first reaction to the thought of 550cc injectors for the MINI was that the need for this size was overkill. But after talking to RC about the use of 550cc injectors was told by them this is a common practice for gaining horsepower in the Sub-compact in Asian as well other German engines. What RC said is that you can have a ECU adjusted by scaling them for idle and WOT that there are gains to be made. They also said the the choice of the Bosch injector specifically the ones being offered by MYNES was a better choice for street engines needing better idling properties over their own Saturated style injectors designed primarily for race engines.
    Here is the contact information that I am sure MYNES will not mind I give out? RC Injectors no longer carries the short style Injector needed to fit in the MINIs fuel rail so they are not a competitor to MYNES but a helpful information source for injectors and willing to answer any questions.
    Check it out with them?
    RC Fuel Injection
    RC Engineering, Inc.
    20807 Higgins Court
    Torrance, CA 90501
    Phone 310-320-2277
    E-Mail: [email protected]
  7. KC Jr 54
    KC Jr 54 New Member
    Jun 3, 2009
    402
    20
    Machine Operator
    Tyler, TX
    I sincerely think you are arguing for just arguments sake at this point. #6 & #7 answers your question just fine, but you seem to have issue excepting it.
    #6 says that the Bosch injectors atomize the fuel better, and that one key point is worth HP. The HP may not be directly related to the size of the injector, but rather what the performance that particular sized injector offers.
    In the end, HP is effected by more then how much fuel is put into the engine.
  8. minimark
    Not arguing at all. I haven't said anywhere that there is anything wrong with the Bosch 550 injectors, their good pieces no doubt! But #6 & #7 do not address my question on weather installing larger injectors on a properly running and tune'd car will in themselves allow a tuner, any tuner to extract more performance or power if you will, from a MINI motor.
    Yes? No? .....or?
  9. jiminni
    jiminni Well-Known Member
    262
    Ca.
    Well this has been taken care of cct1, as they have their Full Access Remote Tune now available :cornut: And after seeing Mike and Jay in action yesterday at the
    shop, this remote tune is The Bomb! There is no other remote tune that can touch this :D Give Mynes a call.
  10. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    Dude... the answer is yes installing larger injectors under appropriate engine operating conditions will increase performance levels.
    How much clearer does it need to be for you?
    "There are to many variables to establish any constant or predictable number". This statement was actually from Venom Performance another fuel injector company.
    mark try actually getting off the MINI forum and contact 1 or 2 fuel injector manufactures and learn from their experience?
    VENOM High Performance does not have currently have any short style fuel injectors needed to fit in the MINIs fuel rail so they are not a competitor to MYNES but a helpful information source for injectors and willing to answer any questions.
    VENOM
    CONTACT VENOM
    Address: 8610 Central Ave.
    Stanton, CA 90680
    Toll Free: 800.959.2865
    Phone: 714.828.1406
    Fax: 714.828.1421
    Email:
    [email protected]
    [email protected]
  11. KC Jr 54
    KC Jr 54 New Member
    Jun 3, 2009
    402
    20
    Machine Operator
    Tyler, TX
    Mynes is not promoting to use ANY larger injector to see increased performance, they are pushing the 550's. Your question IS answered.
    I think you have entered yourself in that state of being "that annoying poster", and doing so, have moved yourself down the priority list. He himself pointed you to #6 & #7 for a reason i believe ;) hint hint hint hint
    HINT
  12. mike@MynesTuned
    mike@MynesTuned New Member
    May 16, 2009
    286
    Well how about this: share with us some DATA on you Injector Pulse at 7000rpm and a dyno graph and i can tell you if your car will make more power :)
    And there's a lot of you with your MINIs tuned, how about sharing some of your dyno graphs with AFRs?
  13. Mr. Jim
    Exactly, so Mark the answer is NO :Thumbsup: But those are alot of "if's" in your question. Can we put this dead-horse to rest? :D
  14. minimark
    Thanks, guess we can shovel a little dirt on him for now... lol
  15. Jan
    Jan Well-Known Member
    377
    382
    1st you would have to be on a dyno capable of putting the proper LOAD on the car to see where you are with the injectors.
    A dynojet which you use ISN'T going to do it.........:popcorn:
    just the facts like you like to say!
  16. cct1
    I read this thinking of the history and bickering over injectors...
    First come the stock injectors. Then, MINI comes out with the JCW, and they....put in larger injectors!
    Then ABF, RMW, etc. comes along, pushes the envelop further, and somewhere in that Jan really starts pushing 440 injectors. And the EXACT same debate we're having now occurred; there were many out there saying 440 was too big. Jan eventually came out on top on this one, and I don't think there are many out there wanting 380's with a more aggressive head/cam/tune than a stock JCW.
    Things get pushed further, Myne's shows credible data, and the cynicism is palpable, just like it was when Jan's arguements for 440's was falling on deaf ears. It's one thing to be critical, it's totally another to argue for the sake of arguing.
    This really isn't a big issue. It's not like 550's are a thousand bucks more than 380's (in fact, you used to be able to get them for pretty much the same price, haven't priced them lately). The 550's give you more flexibility, even if you don't need it at the moment. But we all know what happens--you start adding torque/HP, it's never enough, and then you replace a bunch of components when it would have been cheaper to start with something that allowed you room to grow. The 550's do that. The 440's are probably ok for most, but at the price point, who cares? When you start looking at head, header, IC's and even cams, the injectors are relatively cheap.
  17. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #137 Nitrominis, Feb 6, 2011
    I think M7 offered the first marketed for retail sales larger injectors way back in 04-05? There were three sizes can't remember only the current 400, 440cc. Don at DMH,George Mini Madness,Don R at Mini Mania, Motion Minis,ABF, to name a few all were playing with larger injectors for more power 04-07?? We all knew than that the ECU needed to be flashed for the larger size injectors for driveability. So this is not a new concept.
    Now we have support like MYNES to be able to custom ECU adjust for different injector sizes and tailor injectors behavior a welcome advantage.
  18. ScottinBend
    minimark.........Mynes has shown that the 380's are just about maxed with a tune, regardless of the tuner. I can just about guarantee that if you put larger injectors on your car you would gain a bit of power, but MOST IMPORTANTLY you would gain a lot of piece of mind knowing you are not at the extreme range of the safety-margin on the 380's. I have been watching this thread with a critical mind and have in fact gone to a local German car tuning shop and asked them about the facts/graphs that have been posted. The owner, who has a stable of race cars he mechanics for, was in total agreement. The stock injectors are over-worked on a pullied car, the 380's are at the absolute limit of what he would consider to be a safe installation for a daily driver (mine). He said if he were to do a new tune on my car (something he didn't have the capability to do earlier) he would be only do so with the larger 550's. They would offer the protection against any fuel starvation that will occur at the higher rpm's that a track car would see.
    I can assure you that if and when I can afford to start doing track days again, a new tune with the 550's is going to be mandatory.
  19. minimark
    Scott that's all well and good but it simply doesn't match the fact that there hundreds...possibly thousands of Minis with 380 injectors running 15% pulleys or JCW kits that have successfully been tracking and racing their cars without any record of problems or failures from the use of those injectors. My car would be included in those figures having had them and a tune for a very long time and more than a few track days and thousands of miles driving involved.
    Simple fact is that injector size is not a stand alone power mod but one that should be chosen for the output range of your motor as every auto manufacturer in the world does. With that in mind I have now added a Cam and header and am at the limits of the 380 injectors. New larger ones are on the way for it. They will be 450s because they will be more than enough for my output. After all Ian Stewart ran an entire NASA season ultimately winning a national championship with 450 injectors; and his championship car was making considerably more power than mine will be.. ;)
  20. ScottinBend
    And you completely missed my point. I never said anything about injector size causing any failures. My point was that it was a possibility according to an expert I know personally, not from second, third or fourth hand on the internet. I am with you in regards to my experiences with the 380's and a tune. I have done a handful of track days, although none in the last 2 years, and have not had a hiccup or problem with my car. This is not to say that I never will. I have talked to a professional and he is of the same opinion as Mynes.....bigger is better and safer (depending on use and tune). You may never have a problem. And the injectors are a robust safe design, but you can't claim that they don't have a greater potential for causing a problem compared to the larger ones.
    So please stop trying to fan the flames on this issue. Let it be.
