Engine Drivetrain 1st Gen Cooper S Blimey's 120k service
Discussion in 'Tuning and Performance' started by BlimeyCabrio, Aug 31, 2012.
  1. Norm03s
    Norm03s New Member
    534
    Working at being retired.
    Somewhere in Sykesville. Md.
  2. BlimeyCabrio
    OK, fuel filter is done. Glad that's a once-every-three-years job, because it's a nasty smelly PITA. Drove for a couple hours with the top down and the back seat out to get rid of the gasoline smell.
    The good news.... Blimey goes like rocket ship. Runs better right now, overall, than EVER. First time I've had the combination of all my current go-fast bits working right at the same time.
    Still lower on boost than I should be. Only thing I haven't checked on the pressurized side is injector o-rings. I'll do that sometime.
    Even though peak boost is a little low, the boost builds much, much faster with the almost-new supercharger than it did with my worn-out supercharger. Give it full throttle and boost comes on like a light switch, which is the way it should be. Results in strong torque from about 3000RPM up, with the sweet spot starting at about 4000 RPM in all gears, but especially fun in 2nd-4th.
    :cornut:
    I can well attest to a freshening up making the car feel dang good again. :ihih:
    The Fall Dragon ought to be a real hoot for you now.
  4. BlimeyCabrio
    Since you brought it up, I'll talk about that.
    My old SC had 120k miles on it. My car is harder driven than most, but has only seen a few track days, and has an automatic, so it never exceeds 6250 RPM even with a tune. The oil in my SC looked almost like new, gears looked like new, and oil level was only a little below factory specs. My SC eventually wore out a bearing, unrelated to the oil fill.
    I strongly considered the Recharger. I know some folks who have tuned cars with manual transmissions and higher redlines, and who do lots of track days, have seen cooked oil in the SC snout. If my car had those characteristics, I think the Recharger would be worthwhile to do scheduled oil changes.
    Most of the actual SC failures I've seen were either the result of bearing failure (like mine) or oil depletion due to seal failure. Oil changes do nothing to predict or prevent bearing failure, and would have to be done very frequently to catch a seal problem before the oil was gone and the gears damaged. And, if there were a seal failure, the SC would need to be removed to be rebuilt or replaced anyway. In my case, I don't think it really has much practical value. Either my new SC will last 100k miles, or it won't. The Recharger wouldn't likely impact that materially, on my car. Again, there are other cases where I do think it has value.
  5. KittyMini
    KittyMini Club Coordinator
    1,183
    You're an awesome MINI dad....
    Now just stay away from the groundhogs and you'll be good for another 100K+ miles :Thumbsup:
  6. MINIBee
    MINIBee New Member
    41
    Tampa, FL
    Good job, my friend! MINIBee is at 153,000 now and I have done many of the same things (not myself) a little at a time over the last year. Getting ready to retire her and just bring her out for special occasions. Hopefully getting a Roadster before the end of the year.
  7. BThayer23
    What are you using to measure the boost? Last time I was low on boost, it was a mechanical gauge and the tee that I installed was leaking. If you're using the scangauge, then I dunno, maybe check the vacuum hoses that run around under the intercooler.
  8. BlimeyCabrio
    Scangauge, same as when I used to get higher boost.
    I did change the TMAP sensor a while back.... I guess it's possible that the calibration on the TMAP is different enough that it could be off by 1 PSI or so... dunno.
    But it doesn't feel as strong as it did when I first put on the 17%, when I was getting hella boost.
  9. Dave.0
    Hella Boost. :Thumbsup::lol::lol::lol:
  10. HiFi Guy
    HiFi Guy New Member
    Jul 30, 2012
    46
    Orlando, FL
    #30 HiFi Guy, Sep 4, 2012
    Way cool. I restored a MGB 15 years ago, but this is a whole different league. I tip my proverbial hat to you, sir. :Thumbsup:
  11. BlimeyCabrio
    OK, a couple of days later, and still amazed how much better the car runs with the right exhaust and a fully functional supercharger. Which shouldn't be amazing at all, now that I say it out loud. lol
    Zoom Zoom Zoom baybee. Wish I had Jan and a dyno handy, because I know there's more in there that could be brought out with a new tune.
  12. Hound_va
    Hound_va New Member
    Dec 27, 2011
    Jan will be at Helix in Philly soon... I believe sometime in October.
  13. BlimeyCabrio
    I wish it weren't an 8 hour drive each way to Helix...
    And while I'm at it, I wish I had a unicorn with a Rotrex.
  14. Dave.0
    Yeah Buddy!
    Jan will be at Helix Thursday, Oct. 4th thru Saturday, Oct. 6th.
    Please call Eric at Helix to schedule a time slot. 267-335-4337
    Come on up to Helix and have Jan retune your car.
    Its going to be a good time and I want to see if anyone can knock me off the MINI top spot on the Helix Mustang Dyno hall of Fame.
  15. Dave.0
    8 hours is nothing, just stay the night. Come on buddy.
  16. KittyMini
    1,183
    #36 KittyMini, Sep 9, 2012
    Word.... you can stay with me.
    Hope you're not allergic to cats :devil:
  17. Newbs49
    Newbs49 New Member
    May 23, 2009
    145
    I'd love to take a shot at your record even without meth. But by then the car will be in another persons hands. Maybe I'll drive down to give Jan a little **** and see all you guys again.
    How's the car running????
  18. Dave.0
    My car is running EFFIN great. Good mods and RMW power all year long.
    One of the best and most fun DD's I have every had.
  19. Jason Montague
    :eek6::drool:devil::popcorn::popcorn::popcorn::popcorn::arf::Thumbsup:
  20. KittyMini
    1,183
    Hey, I'd help out any fellow MINI owner :cornut:
