2nd Gen R56 Cooper S Blown head gasket
Discussion in '2nd Generation: 2007+ R55 through R61' started by itsmewutup, Feb 27, 2013.
  1. itsmewutup
    itsmewutup New Member
    Apr 11, 2012
    351
    67
    So I blew my head gasket today. Anyone know of where I can get a multi layer steel head gasket? Might as well do it all right from the start.
    2008 MCS Turbo
  2. InjectedGT
    InjectedGT New Member
    Feb 15, 2013
    55
    24
    anywhere... a quick search on autozone's website as well as rockauto.com bring nothing but MLS results. Did you attempt to search parts stores yet??
  3. Tummi_Gummi
    Tummi_Gummi New Member
    Nov 19, 2012
    384
    103
    Online Sales Manager
    Springfield, MO
    are you sure its your head gasket? check oil and coolant for cross contamination.
  4. Gizmo
    Gizmo New Member
    May 22, 2012
    487
    283
    Flemington, NJ
    Waymotorworks.com
  5. itsmewutup
    Apr 11, 2012
    351
    67
    Found it on rockauto.com. auto zone and advance auto are both a no go. Neither have them. Yes it is definitely a head gasket. I stopped in the road and it poured out a puddle of a nice slimey mix of oil and coolant. Didn't find any on waymotorworks.com.
  6. BlwnAway
    BlwnAway Well-Known Member
    Nov 24, 2011
    474
    290
    You may have to go Copper instead of steel, don't know if there as easy to find as our gen 1's though.
  7. Metalman
    #7 Metalman, Feb 28, 2013
  8. BlwnAway
    Nov 24, 2011
    474
    290
    Also, don't forget, when it comes to Way, Chad, Helix and our other favorite vendors, just call them, just because something isn't up on their website, doesn't mean they don't have a way to get it.
  9. BThayer23
    If you're going to do it right from the start, get the head machined flat and talk to your machinist before you buy a new gasket. You can usually get head gaskets in varying thicknesses, depending on how much material was machined off the head. If you have more than 100k on the motor, you might benefit from a valve job, and you should certainly get that head cleaned well while it's off to get rid of any carbon deposits.
    I looked into this a few months ago when I thought I'd blown my head gasket. Turned out to be a rogue oil analysis. Prices weren't bad - $78 to clean, pressure test, and resurface the head, plus another $75 if I didn't want to remove and replace the cam myself.
  10. Little big car
    Little big car New Member
    Jun 20, 2012
    72
    Chesapeake, VA
    Are you really running boost that much higher than stock to need a metal HG? I have never heard of BHG's being common on these engines so I would assume that the stock HG holds pretty damn well.
  11. itsmewutup
    Apr 11, 2012
    351
    67
    My brother and I plan to do a full valve cleaning job as well as porting and polishing the head
    and machining it. We're just gonna take our time and get it all done good.
    Its highly likely that I will be installing a 10lb NOS tank....
  12. itsmewutup
    Apr 11, 2012
    351
    67
    I will keep that in mind for future reference.
  13. Little big car
    Jun 20, 2012
    72
    Chesapeake, VA
    Well OK then! Have at it.
    And if you are ever out my way I want a ride! :Thumbsup:
  14. itsmewutup
    Apr 11, 2012
    351
    67
    I will b at the dragon as long as my POS is running lol. Wish I'd done my research before buying the 2008
