2nd Gen R56 Cooper S Boot not always closing fully
Discussion in '2nd Generation: 2007+ R55 through R61' started by bravos1, May 8, 2012.
  1. bravos1
    bravos1 New Member
    May 5, 2012
    89
    22
    San Jose, CA
    '09 MCS r56
    Sometimes when I close the boot, it will not close all the way as if it was just softly shut where it latches but not close completely. This sometimes happens even when closing w/ enough force where I think it should close normally. It's almost like the air pressure in the cabin is fighting back :)
    It's not that big of a deal because I just close it again, but it's a bit frustrating. Anyone else have this?
  2. bluefox280
    bluefox280 New Member
    May 9, 2012
    34
    12
    Mechanical Engineer
    Westminster, CO
    Checked the bump-stops on the hatch to see if you can recess them farther?
    If you're convinced it's air pressure, try cracking a window and repeat closing it.
    If it doesn't change anything, you're back to a latch alignment or bump-stop details.
    - Erik
  3. BThayer23
    Try lubing the hinges, too.
  4. KittyMini
    KittyMini Club Coordinator
    1,183
    I had this problem once in a while on my '09.... it was that shelf/privacy thing on the strings.... it would not be lined up sometimes. See if that is the issue.
    I've also found the strings & balls getting in the wrong place occasionally causing the boot to not want to close.
    By all means keep the boot hinges lubed. If they start binding they will fatigue the metal & they will break.
  6. grodenglaive
    grodenglaive New Member
    Apr 3, 2010
    313
    68
    Ottawa, Ontario
    you definitely want to keep your balls out of the way
  7. B.A.D.
    I've heard that as they get older they tend to hang lower then when they were fresh out of the factory.
  8. BlimeyCabrio
    Lubing your boot, sagging balls, air pressure in your boot...
    My, what an informative thread.
    ^ We aims to please ya...
