1st Gen R53 Cooper S Bouncing Tensioner?
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by BlimeyCabrio, Sep 5, 2010.
  1. BlimeyCabrio
    Reman unit ordered. I'll compare before I install it.
    It was definitely NOT smooth -
  2. BThayer23
    Blimey needs some smooth...
  3. minimark
    LOLOLOLOL
  4. ScottinBend
  5. BlimeyCabrio
    I used that thing on my butt once. Never again.
  6. ScottinBend
    Did you have to powder it after?
  7. BlimeyCabrio
    Dang - that's what I did wrong.
  8. BlimeyCabrio
    Well, crap.
    Apparently, reman MINI alternators do not exist. Even though RockAuto lists then from three different remanufacturers (AC Delco, Denso, Remy), when they tried to place orders with all three remans, all three said "oops, we don't have any and don't know when we will have any". So back to square one.
    That said, I'm having second thoughts about the alternator diagnosis. Why? Because the car only exhibits the behavior when I shift out of park into D or R. That should make no difference to the alternator while still sitting still at idle... but I can turn the vibration on and off at will, simply by moving the shifter. But when I check under the hood with it vibrating, the tensioner is definitely bouncing some, and the noise seems to be emanating from there, even checked with a stethoscope.
    I'm baffled.
  9. mini_racer
    mini_racer Well-Known Member
    Engr Manager
    It is possible that you have multiple contributing factors. I would still suggest to go to the auto parts store to feel a new alternator so you can determine if yours is abby normal. If it is then you still need to remedy that issue anyway.
    It is often difficult to identify issue #2, until issue #1 is resolved.
  10. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    It's also a ressonance effect...
    think of it as a tuning fork. When it's hit near the "natural" frequency, it's amplitude is very high. When hit at a frequncy far from what it likes to ring at, it won't bounce much.
    Matt
  11. BThayer23
    Hmm, that's a tough one. So the vibration only occurs when the driveline is loaded, and it's shaking the engine hard enough to oscillate the tensioner. Check your lower engine mount for tears? Maybe a bent axle? No, the axle's not rotating. Hmm, weird.
  12. BlimeyCabrio
    Just had the lower mount out this weekend... looks fine.
    Yep, only when the driveline is loaded a little, but at low load and low speed. Does it through a range of several hundred RPM (900-1800ish), so it's not like it's doing it at one very specific engine speed. Once I get above "driveway" speed and RPMs, it stops vibrating. Shift into park, stops vibrating. Haven't tried neutral, but will.
    Nothing that I can think of changed to coincide with the appearance of the vibration. I changed tranny fluid a couple of weeks before this started. Crank pulley (ATI) has been on for several months. TSW engine mount for a couple of months.
    I'm not convinced that there's not an issue with the alternator bearings... but it just seems really weird to me that the symptom is completely dependent on transmission engagement. I suppose that changes drivetrain harmonics a bit as Dr. O suggests and that could be the difference...
  13. werD
    werD Club Coordinator
    May 19, 2009
    64
    Slave to technology...
    Nashville, TN
    Solid advice - my original R53 had the same symptom post tensioner install (and new pulley). Three free tensioners later from the dealer, they opted to try the idler pulley and all was well...
    Inexpensive part to try as well.
  14. BlimeyCabrio
    Interesting. I'll try an idler if I can't find another culprit.
    For now, seems improved. I installed 17% pulley, brand new tensioner assembly and shorter belt on Saturday. Have only driven it once since... doesn't seem to have the mega vibration like it did - so far.
    I also checked all accessories. EVERYTHING was nice and smooth... including my alternator... weird... definitely was not smooth a week or so earlier.
    Slightly related topic... for some reason, my car doesn't obey the laws of belt length physics. Everyone seems to say that NAPA 060535 should be plenty short / tight with a 15% pulley and standard size crank pulley. Well, on my car, a new 060535 belt will only show about half a hole in the tensioner. I've confirmed this with multiple belt swaps and tensioners.
    But a 060532 is the ticket for me (now with 17%). It's about 8mm shorter and that makes it tight to install, but leaves a whole hole visible when on.
  15. JCC
    JCC New Member
    Dec 15, 2009
    190
    Installation Manager
    Sachse, Texas
    Interesting about the belt. Got pics?
  16. BlimeyCabrio
    No pics.
    Most folks seem to coach that to ensure no belt slipping, etc. you want to be able to see at least half a hole visible on the tab sticking out through the top of the tensioner. Ideally an entire hole. By the time a 060535 belt gets stretched in a bit, I'm at almost none of the last hole visible.
  17. BThayer23
    Is the geometry slightly different for an automatic? Maybe MINI uses the same belt for manuals and automatics and takes up the slack with the tensioner. Weird how the alternator goes from bad to good, too.
  18. werD
    May 19, 2009
    64
    Nashville, TN
    This is almost funny - I had similar belt misery amongst diagnosing the idler pulley. I *think* I wound up using the JCW belt from the dealer with my m7 16% reduction, been a while since I dealt with that and I could be mistaken. The NAPA was too short/tight in my setup to jive.
    But I'd work on the other trouble more to ensure it doesn't fubar everything and leave you stranded... Like mine did. :crazy:
  19. BlimeyCabrio
    All seems well at the moment... Vastly improved... Good, but definitely odd about the alternator.
    I don't see how anything would be different on the belt drive on an auto... All the same pulleys in the same locations.
  20. OutMotoring
    OutMotoring Club Coordinator
    69
