1st Gen R53 Cooper S Bouncing Tensioner?
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by BlimeyCabrio, Sep 5, 2010.
  1. jhiggs26
    jhiggs26 New Member
    May 24, 2009
    159
    10
    Anybody know the part # on the idler pulley bearing. I just replaced a couple idler bearings on a Mazda. Under 10$ for both bearings plus my time intead of $50-$80 per new pulley with bearings. Thanks.
    Jeremy
  2. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    Now Jeremy
    with info like that out there, how will I ever sell more glossy renderings?
    Anyway, the way to find that out is to take one apart and see. Work back from the dimensions. While it's got a decent life, it's not the best made part on the car....
    Matt
  3. jhiggs26
    jhiggs26 New Member
    May 24, 2009
    159
    10
    Oops sorry Matt. I was hoping somebody had one in hand and had the part #(Keith perhaps). I've yet to see one fail-yet. Probably a good call to change the idler bearing or whole pulley and bearing while doing a belt change around 75-100k as a matter of course.
    I'm sure if you offer up a lighter rendering and keep parasitic drag to a minimum with a larger more stout bearing then people will flock to it!
    Jeremy
  4. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    Sometime I'll take mine off to check...
    I screwed around with the model a bit. Even built a roller bearing that can take axial loads!
    And a print out of this vaporware will be very, very light! As far as minimizing mass, I'm not any good at the FEA part of the software. Most aftermarket guys tend to overbuild for just this reason. This design uses two roller bearings, and a spacer so you'll be able to torque the crap out of the mounting bolt and not screw it up. But as of now, it's just an idea....
    Matt
  5. k-huevo
    k-huevo Club Coordinator
    159
    Pipe Creek, Texas
    I'll look.
    The idler bolt fastens to the timing chain cover made of thin aluminum, it can't be tightened excessively.
  6. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    Guess I'll have to make....
    some really good vaporware bolts too!
    Matt
  7. BlimeyCabrio
    When you machine mine, don't cut out that pie slice, otherwise I'm afraid my bouncing tensioner problem might recur.
  8. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    It comes pre-cut...
    but don't worry, I include some krazy-glue so you can put it all back together!
    But without the cut-away, you can't see how good a job I did on the vaporware bearings! And the vaporware crush sleeve in the center would never be seen. That would just be a crime....
    Matt
  9. jhiggs26
    jhiggs26 New Member
    May 24, 2009
    159
    10
    Thanks and no rush at all Keith.
    Yes no need to exceed torque spec. As long as the inner race is secure the path of least resistance will take hold.
    Jeremy
  10. werD
    werD Club Coordinator
    May 19, 2009
    64
    Slave to technology...
    Nashville, TN
    LOL - nice.
    Glad the idler was the culprit and easily fixed!
  11. papa-j
    papa-j Active Member
    378
    112
    Minneapolis, MN
    NTN bearing: 6203 LHA
    I took a look at my new oem idler pulley and the bearing is NTN 6203-LHA
    Hope it helps. Looks like VW/Audi use it for the same application too.
    BEARING P/N 6203-LHA
    COMMENTS 2 Rubber seals, 2 x O-Rings
    I / D MM 15
    O / D MM 40
    W MM 12
  12. jhiggs26
    jhiggs26 New Member
    May 24, 2009
    159
    10
    Alrighty then. An off the shelf 6203! Same bearing for one of the snout bearings and both front rotor pack bearings in our M45's, minus the seals.
    Jeremy
