Bypass valve DELETE!!
Discussion in 'Car Builds, Projects, Idea's Experiments' started by Thumper460, Oct 4, 2010.
  1. Thumper460
    Thumper460 Active Member
    May 26, 2009
    559
    94
    United States Navy ..Retired
    10% ?? then the SOP better be worth it or It wont be done!! 2-3 MPG.
    Thumper
  2. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    Backing off the stop set screw and wiring tie shut the valve along with plugging the vacuum port controlling valve operation was the first way I discontinued the operating BPV. I did not notice any discernible difference in the IATs, timing,coolant temperatures or total boost but I did read boost start in at a lower RPM range. I lost about 2-3 MPG when I did monitor it at 60 mph 0 wind level highway pulling steady at 16-17inHG.
    The mid range RPM surge or "Yo-Yo" was reported by BMW/MINI very low percentage of MINIs but got forum attention mostly I believe on nam? At that time 03 -04ish I read every TSB available pertaining to this concern and surprisingly the BMW/TSB reports compared to forum reports were extremely low? This would mean in reality a handful of MINI actually experienced the effect? You would think that most MINIs were still under warranty and that being a warranty concern more reports on TSBs? I will say in the last few years that on some that felt they were experiencing the "YO-YO" effect a good tune seemed to solve the feeling?
  3. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    Early on...
    in 2002, BMW was putting out ECU file updates like Moms passing out candy on Halloween. I think the problem was pretty bad and widespread, though not universal. BMW/MINIs history was more to give new ECU files as released, but not issue TSBs or the like. Whether you wanted it or not, they'd slap a new ECU firmware version on you car when you went in for your "free" service!
    Like Jan said, it was poor programming of the ECU that lead to the problem, but as tunes were harder to come by then, and I don't think any (or very, very few) were doing dyno tunes, the only way to supress it was tweaking the BPV or the like. Anything that shifted how the valve opened or responded to vacuum and RPM could move the transition away from the problem spot. These tweaks included:
    1) Wire Tie. (Ryephix 1, buy our buddy Ryan)
    2) Stiffer Spring. (Ryefix 2 or DT BPV, developed by Ryan again, now sold by DT)
    3) Relocation of vacuum tap (Vacuum Gain System, from Andy at Ross-Tech)
    4) Flow restrictor in vacuum line (M7 would give you an orifice if you wanted one, it would slow the transition from open to closed)
    5) Worked over BPV (Like what I did)
    Anyway, cause of how all the stuff interacts, any one solution didn't solve everyone's problem. Eventually BMW/MINI got the tunes improved to the point where it's become close to a non-issue. Yet some of the solutions live on. Me, I'm still running my worked over BPV and the VGS....
    This was a perfect example of how not to do nested feedback loops and showed how coupling of negative feedback systems can lead to instabilities up the wazoo! Each feedback mechanism in isolation would seem to be stable, but when allowed to couple, you'd get yo-yo.
    And that concludes the MINI history lesson for the day....
    Matt
  4. BlimeyCabrio
    When my wife and I couple our feedback mechanisms, we get yo-yo too.
    Weird.
  5. Thumper460
    May 26, 2009
    559
    94
    Next stp.... the Drag Strip!!
    OK... got some pictures for the novice that might want to do this after I see IF it is worth it on the TRACK.. cool??
    Just me...........................................
    Thumper
  6. Thumper460
    May 26, 2009
    559
    94
    and what it looks like on the engine....
    Good thing, is that using a zip lock you can lock the BP or release it at your desire..
    IF there is a shown power / Qtr. mile ET and MPH gaine, this could be a fast and easy power builder..yes??
    More later..
    Thumper
  7. minimark
    When do you plan on taking it to the track?
  8. ScottinBend
  9. Thumper460
    May 26, 2009
    559
    94
    Short up date..
    Went to the local ' straight stretch' of road.. ( traffic.. was there!!) made a few slow roll acceleration runs. Was it true power... or like when the 'car is washed and feels faster??'
    The acceleration was crisp in low range, SOP seemed to pull harder low to mid. ( Top was the same 'SOP feel' whether tied or not) Could not do any 30-70 or 70-100 runs do to traffic. ( thus the track )
    more later......
    Thumper
  10. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    Doing it this way....
    you will only get a bit of benefit in the very first gear that you roll onto power in. This is the only one that will have the valve open at all. Once at high RPM under load it will be closed.
    Matt
  11. Thumper460
    May 26, 2009
    559
    94
    Roger that Matt. However it is torque down low, that makes it all move, and IF there is a way to increase the power sooner... then it is a performance increase thru the entire range.. even though wot it is closed anyway.
    Say... I am at a no load crews of 50 mph... and nail it, the power will be right there, and that 'right there' could mean the difference of a car length or so against another NON modified car?? Yes??
    This is why I am going to the track.. to see if this is worth the time ( money should be only the cost of a zip tie..LOL). For guys looking for anything to increase power at a given time... might be worth it!! To a track car where boost is always in full.. it would not be worth anything???
    Thumper
  12. minimark
    When are you taking it to the track for testing?
  13. jdm_love
    jdm_love New Member
    Mar 3, 2013
    Any updates on this bypass valve delete? I own a 2002 kompressor and wanted to do this but no one with my car has ever did this! Im trying to research all the benefits and disadvantages to this modification.
    I have read many disadvantages to come from deleting the bypass valve. I read that it can cause compressor surge? I'm not sure how that would work on a supercharger but when the throttle is closed suddenly in full boost it does make sense to have some sort of problem right?
    I would appreaciate any help
  14. Tummi_Gummi
    Tummi_Gummi New Member
    Nov 19, 2012
    384
    103
    Online Sales Manager
    Springfield, MO
    No because this is why.
    This whole area has no boost
    INTAKE FILTER--> THROTTLE BODY --->
    Then from
    SUPERCHARGER ---> ENGINE--->
    is all compressed but when u let off the throttle it stops feeding in compressed air that is still pushed through the motor. It will more likely cause lean spots off the throttle. Compressor surge happens on my turbo because the compressed side of the turbo is where the throttle body is. Since there is never any boost on our throttle body(sc mini) then it shouldn't surge pressure anywhere.
