Unbolt the pitch control arm, remove the nut from the engine mount to hydraulic damper, raise the engine to remove weight from the damper, unbolt the bracket from the engine block to the damper, unclasp the sensor connector, and remove. Here is a file with photos that may help. Of course you don't need to remove all the other things in the how-to.
