1st Gen R53 Cooper S Can someone explain motor mounts to me
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Pac10sux, May 26, 2015.
  1. BlimeyCabrio
    Yep, I've run every combination of OEM, poly inserts, full poly mounts, and VibraTechnics. The VT mounts are the best by far in every way. As they should be, for the price.
  2. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    My 2006 R53 has 92,000 miles, if I install the three Vibra-Technics mounts:
    MIN906M Rt Eng Mount
    MIN910M Lt Eng Mount (trans)
    MIN915M Torq Link
    Is there any other mounts that I should replace or do those three cover everything?
  3. BlimeyCabrio
    Thats it for engine mounts. Already on poly LCA bushings?
  4. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    Thank you for the engine mount response.
    I have not done LCA bushings yet. My original LCA bushings seem to be hanging in there but I know replacing the LCA, power steering, and sway bar bushings needs to be a project in the near future but I am not excited about dropping the subframe so I have been putting it off.
  5. BlimeyCabrio
    On that age car, I'd refresh the power steering hoses and ball joints also, while I was in there. I had all that done on the same time on my car.
  6. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    Yes. Thank you for the reminder on PS Hose and Ball Joints.
  7. fishmonger
    fishmonger Well-Known Member
    May 13, 2015
    984
    769
    Madison, WI
    Lovely. More parts on my winter to-do list :)
  8. RussWK
    RussWK Active Member
    Apr 1, 2011
    106
    61
    5 years ago I put in these softer orange poly motor mounts from Madness. They are a softer compound polyurethane that still limits engine movement without noticeable NVH. I maintained the OEM upper mount to prevent NVH. I have the Borla Street Catback exhaust. There is just barely noticeable NVH that disappears above idle. The car is as smooth, if not smoother, and quiet at stock yet has less engine movement and better shifting. No drone at all at any speed. Have taken trips of 900 miles in one day and arrived with no fatigue. I believe this was the perfect combination after reading all these posts, and have not experienced any of the too-hard or too-soft combinations.
    I also have the ATI Super Damper which seemed to me added some additional smoothness at all engine speeds. It is also supposed to add 1/2 lb of additional boost due to 0.8% larger than stock.
    Madness MINI Cooper Polyurethane Engine Bushings - Madness Motorworks
    --Russ
  9. ColinGreene
    ColinGreene Well-Known Member
    438
    293
    Orange county Ca
  10. BetaMini
    BetaMini New Member
    Aug 2, 2012
    218
    98
    eComm
    New Albany, OH
    I have the VT upper, and a poly lower. Really want to change to the VT lower also.
  11. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    I was on your website yesterday looking at pricing. I am just not ready to spend $800 for engine mounts. I know they will be good but still expensive for mounts so I will live with the NVH from my TSW and stock mounts a little longer.
  12. fishmonger
    May 13, 2015
    984
    769
    Madison, WI
    it's just $705 :D
  13. sethat46
    sethat46 Well-Known Member
    Apr 25, 2012
    1,560
    413
    Financial Sales
    Ohio
    Piece meal that $800 together. It'll be worth it. I'm still working on getting the drivers side mount. I have 2 of the3.
  14. Goldsmithy
    Jan 30, 2015
    1,748
    982
    TCB
    Main Street in the land of Oz
    I will replace my engine mounts when needed. I will use Vibratechnics Mounts. You always pay for what you get...you don't always get what you pay for.
  15. myles2go
    myles2go Active Member
    May 7, 2012
    589
    223
    collecting a paycheck
    WI
    As mentioned above, do it in steps. I replaced the upper mount with the VT first, because the oem unit crapped out. Then I got the lower mount the next year. I'm still using the original transmission mount for now, but will be switching to the VT at some point.
  16. ColinGreene
    438
    293
    Orange county Ca
    Its ok I understand completely.
    I do have the lower in stock though!
  17. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    For my 2006 R53 it is $310+$325+$155=$790 plus shipping.
  18. fishmonger
    May 13, 2015
    984
    769
    Madison, WI
    darn it, you're right. Now that kills it for me :)
    Actually, I just put upper and lower new OEM mounts in there. Not going to change that for a while. Gearbox mount will get done when I rip into the car for clutch and other major items again, such as control arm bushings. None of that appears to be needed right now. Got new exhaust on the more immediate wish list and that costs about the same as these motor mounts.
