Car Weights
Discussion in 'Track Days & HPDE's' started by Nathan, Sep 8, 2009.
    #1 Nathan, Sep 8, 2009
    Since a few of us put our weights in this thread I thought it would be fun to create a table.
    PM me with your info and I'll add it.
    Click on a column head to sort.
    Car Weights
    Column 1 Column 2 Column 3 Column 4 Column 5 Column 6 Column 7 Column 8
    Name Weight /lbs Year Model Gas Level Sunroof Comments
    drmike@txwerks 2593 2003 MCS 1/3 No Driver's seat replaced, harness bar and harnesses in place, rear seat in place
    Nathan 2624 2006 MCS 1/2 Yes No rear seats and some dynamat under the rear seat delete, much lighter front seats, 6pt harnesses and a roll bar
    M^Cubed 2800 2005 MCS JCW, Sport Pack, Sound deadening added, sub and amp
    goaljnky 2716 2006 MCS 1/4 JCW with all options
    goaljnky 2712 2005 MCc 1/4
    btwdriver 2612 2007 MCS 3/4 Yes No rear seats
    Bimmer Lite 2664 2005 MCS No Cloth Seats, removed the rear seat bottoms and backs and all of the hardware. Includes driver weight
    scott@txwerks 2650 2003 MC
    Alan 2597 2003 MCS 1/2 No Rear seats removed
    ScottinBend 2648 2004 MCS 1/2 No On some questionable scales
    Ryephile 2470 2002 MCS Full No Stripped interior
    roach13 2367 2006 MCS 1/2 No Stripped interior, caged, one seat
    quikmni 2520 2006 GP ~2 gal No Added rear insulation, Milltek cat-back, BBK
    Mrsideways 2422 2003 MCS 1/2 No Race seat, passenger and back seat removed, light weight battery. 1 gallon of meth. 15x8 wheels, lite weight aluminum inverted shocks. Race weight is 2650lbs with driver. We add a fair bit of lead to the back.
    Minidave 2670 2003 MCS JCW Mostly Full Yes S'lites, no mods and loaded with factory options
    Nitrominis 2775 2002 MCS Full Yes Interior Stereo system/w sub box 3 amps weighed in at 125lbs 10lb NOS bottle Full
    Minidave 2885 2009 Clubman Full No Auto Trans, 17" S-Lites
    2765 2002 MC Full Yes CVT
  2. Mike
    Mike New Member
    Oh cool, this is a great idea.
  3. PGT
    PGT Wheel Whore
    Federal Gov Contracting
    Leesburg VA
    ooh...nice color fade on the subject line :D
  4. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    hahah, now you are going to make me go weigh my car to get an actual weight.
  5. Bimmer Lite
    Bimmer Lite New Member
    English/Journalism teacher and writer
    NJ
    Awesome! My car is a 2005 (for above).
    - Marc
  6. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    Same here 2005 - JCW - Sport Pack - Sound Deadening - Subwoofer + Amplifier in hatch.
  7. ScottinBend
    oh and mine is a 2004 with about 1/2 tank and no sunroof.
    :blush2:
  8. Ryephile
    Ryephile New Member
    Apr 9, 2009
    299
    122
    Yes!
    Metro Detroit
    #8 Ryephile, Sep 10, 2009
    My circle-track-racing co-worker was kind enough to bring in his Intercomp scales today. My stripped-out 2002 MCS "#848" without sunroof and full tank of gas weighed in at 2470, with 64.1% on the front and a 49.5% cross. Its honestly much more than I expected, but does appear in line with the rest of the weights here considering how extreme my setup is.
    By "stripped-out" I mean light flywheel, crank pulley, Rev.A Quaife, Cooper-style exhaust, Braille 15# battery, Sparco seats, Autopower 4-point bar, Schroth 6-point belts, lightweight suspension, brakes, wheels, and of course stripped out interior.
  9. beaner
    beaner New Member
    44
    great thread idea. my car is currently on a plasma cutter, air saw, hole saw weight reduction program. i will also be doing a sunroof-ectomy. the car will be on a high fiber (carbon fiber) diet. i hope to get the dry weight down to 2050#. i'll let you know how it goes.....i also hope to shed about 20 lbs. of unneccessary driver weight.
  10. Nathan
    Did you do the R56 trailing arm swap...thats 12lbs right there.
    You can shave another 8lb over a Braille Battery with one of these too...
  11. Ryephile
    Ryephile New Member
    Apr 9, 2009
    299
    122
    Yes!
    Metro Detroit
    Don't forget the H-Sport Comp rear bar is lighter than stock, as are Helix rear control arms, Wilwood 11.75" or TSW brake kits. Tossing the A/C is worth about 20 pounds, and going to lightweight seats [as in <20/each] will save 50 pounds in blubber.
    --->beaner; you have any pics or info on your project?
    Added a GP to the list....
    Send me your info and I'll add it.
  13. Chase
    Chase New Member
    hmm. in need to weigh my car now. i need a corner balance too.
    thinking of putting a solid roof on for the spring
  14. imspencerwithanr53
    imspencerwithanr53 New Member
    May 27, 2009
    117
    Barista
    Portland, OR
    Time for a Diet :p
    I need to put my new seats in and then I will hit the scale :)
  15. Thumper460
    Thumper460 Active Member
    May 26, 2009
    559
    94
    United States Navy ..Retired
    My 06 MCS with only option "cruise control" weighed in at 2780 Lbs. ( with my heavey but in the seat. I weigh 200 lbs)
    Good table...
    Just me..............................
    Thumper
  16. Nathan
    Updated list with new entries.
  17. Minidave
    4,594
    If you want to add mine, my '03 JCW loaded with everything weighed 2760 with a mostly full tank of gas, S'lites, sunroof and only factory options, no mods.....
    I'm taking my '09 Clubman S to the track in 2 weeks, I'll have that one for you then. It is an automatic, no sunroof, with the same tire/wheel combo that was on my '03.
  18. Nathan
    Updated
  19. Ofioliti
    Ofioliti New Member
    35
    Professor
    ... always curious
    What's the easiest way to weigh your car? Can one just go to one of those truck weighing stations?
  20. Minidave
    4,594
    Sorry, just found my notes - 2670, not the other way round.....
    Yes, truck scales, or your local feed store might be more accomodating if they're not busy. Moving and storage places also have truck scales....
