Suspension Brakes Caution when changing Brake Hoses
Discussion in 'Tuning and Performance' started by grodenglaive, May 19, 2011.
  1. grodenglaive
    grodenglaive New Member
    Apr 3, 2010
    313
    68
    Ottawa, Ontario
    So, I decided to replace the rubber brake hoses with braided SS hoses. At first it was a very simple job (loosen 2 nuts, remove rubber hose, attach braided hose). The fronts took about 5 minutes each, but on both rear lines the attachment nut (where the steel line connects to the hose) was rusted onto the steel line. When I thought I was loosening the nut, I was actually twisting the brake line!
    It snapped off and I ran around trying to find something to plug the end, while brake fluid was running out (ended up using epoxy putty).
    I ended up paying for a tow and had to have both rear brake lines replaced. The mechanic said it is pretty common for those fitting to rust on. It's a pretty dumb design.
    Anyway, if you are planning to replace your brake hoses, be sure to soak the fittings with penetrating oil at least a day before and be careful.
  2. BThayer23
    Good tip.
    I'm gonna throw another one out there. If you're changing brake hoses, use a long stick (crutches are perfect) wedged against the front seat to depress the brake pedal a few inches. This will push the master cylinder in and isolate the brake system from the reservoir. Brake fluid will still drip from the open lines, but very very slowly. I had my front calipers off for three and a half weeks and topped off the master cylinder twice.
  3. grodenglaive
    Apr 3, 2010
    313
    68
    Ottawa, Ontario
    that would definitely make things easier
