Suspension Brakes 1st Gen Cautionary tale of cheap studs...
Discussion in 'Tuning and Performance' started by KC Jr 54, Aug 18, 2011.
  1. SNEEEZY - Erika
    1,212
    116
    Female
    My roomie in school used to tell 'em that her police officer boyfriend should be home in 10 minutes or so....
    ba dum dum!
  2. Metalman
    7,700
    Urp de Durp Durp....
    [ame=http://www.youtube.com/watch?v=jv4m41viy4I]RX7 wheels fall off - YouTube[/ame]
  3. SNEEEZY - Erika
    1,212
    116
    Female
  4. KC Jr 54
    KC Jr 54 New Member
    Jun 3, 2009
    402
    20
    Machine Operator
    Tyler, TX
    Yeah, PB Blaster a little before you start is good, but be VERY careful getting that stuff on brake components. Have a can of brake clean close by for when you do though ;)
    The double nut trick is what i did to get the oold ones off. I use Dorman lugnuts, and with the being a 19mm, i was able to apply more then enough torque to get them out. Pretty generic lug nut that can be found at most auto-parts store. (m12x1.5)
    Another trick i heard of AFTER (ofcourse) was to use a bit of heat from a torch and wick a birthday candle into the threads. Apparently the wax does find its way to where you need it, and pulling the stud out is pretty damn simple. Only concern here would be the wax leaving behind small traces and the loctite not being able to act accordingly ? Maybe, but IDK.
    Good luck to those, and if you are about to pull out the old ones, get a thread chaser so that you can clean the threads up and get any left over corrosion out. Honestly, get a couple...or four. Mine was pretty tired after to two BAD hubs.
  5. cct1
    That's what happens when you have the right sized bolts (which he did) and the wrong pitch (which he did also).
  6. Professor
    Professor New Member
    69
    BMW / MINI tech
    Kentucky
    Just picked up the set sold by Bimmer World. Look just like the Turner ones so maybe they are the same.
    But I do like them over my old TSW ones. The base seems to be designed a bit better where it threads into the hubs.
    10,059
    Thanks for the update. Nice looking wheels!
  8. Professor
    69
    BMW / MINI tech
    Kentucky
  9. BThayer23
    You can't go wrong with either BW or Turner studs. Fantastic craftsmanship, quality materials, premium price.
    10,059
    Man, wish I had known more when I bought my studs. POS brand as I recall. IMHO quality is worth the price especially for something as important as wheel studs.
    I have learned that lesson many times, but still get bitten by the cheap price low quality bug once in a while.
  11. Angib
    My sister is going to be really disappointed about that.
    No, wait.... you mean 'wheel studs'?
    Boy, did I misunderstand this thread's title....
  12. Metalman
    7,700
    Shame on you....:D
    Does your sister follow your postings on M/A? You could have some real splaining to do for the next Holliday family get together.
