2nd Gen R56 Cooper S Ceramic Coating Turbo and Manifold
Discussion in '2nd Generation: 2007+ R55 through R61' started by cerenkov, Aug 9, 2015.
  1. cerenkov
    cerenkov New Member
    Mar 6, 2014
    67
    30
    Nuclear Engineer
    Wake Forest, NC
    My new turbo in coming in next week and was debating about getting it and the exhaust manifold and downpipe ceramic coated (Swaintech - White Lightning).
    Is the cost benefit there?
    Estimated costs from website are:
    Exhaust manifold - $150
    Turbo housing - $100
    Downpipe (high flow catted) - $100
  2. BlimeyCabrio
    It will definitely keep that area of the bay cooler. Just a matter of what that's worth to you.
  3. rckrzy1
    rckrzy1 Member
    Jul 14, 2015
    34
    11
    can you run without the heat shields if you go this route ? Way said it will melt your valve cover without the shields.
  4. cerenkov
    cerenkov New Member
    Mar 6, 2014
    67
    30
    Nuclear Engineer
    Wake Forest, NC
    I would still use the factory heat shields. And with meth installed my intake temps rarely go over 90F so I'm wondering if there are any power gains for example if it helps with scavenging.
    I'm probably over thinking it and it's probably only beneficial to tracked cars and not 100% street cars but if there is a noticeable gain then I would rather do it now.
  5. DneprDave
    Anything that keeps heat in the turbocharger will improve its efficiency.
  6. Ryephile
    Ryephile New Member
    Apr 9, 2009
    299
    122
    Yes!
    Metro Detroit
    I have my turbo Miata's exhaust manifold, turbine housing, and downpipe all coated with Swaintech White Lightning. I just finished doing its first track weekend and the coating is still aesthetically flawless, only slightly silvered instead of pure white. My EGT's at full load are a moderate 1200°F, but the outside of the manifold measured about 750°F, so that's a big difference. I also have a heat shield as the turbine is near the brake reservoir, it's stainless and gold foil coated facing the turbine. The far side of the heat shield after a session was only 170°F, keeping my brake fluid from getting too warm.
    So, White Lightning, yes do it! Also, factory heat shields, use them too!
    If you send them the turbine housing, make sure you take pictures of the turbo clocking before taking it apart.
