Changed air in my tires.
Discussion in 'Wheels & Tires' started by goaljnky, Dec 19, 2009.
  1. goaljnky
    3,105
    394
    Update: went to CF valve stem covers. Wow! Need to schedule a track day to log the data.
  2. lotsie
    stagehand/part time detailer
    Right here
    All my fancy valve stem caps have been ripped off. Do the CF ones come with locks?
    Mark
  3. goaljnky
    3,105
    394
    No locks. But knowing where I live and the risks associated with theft I used two part epoxy to keep them secure.
  4. lotsie
    Right here
    :lol:
  5. cct1
    To save some weight on the track, I finally broke down and bought some carbon fiber underwear. I refuse to use epoxy to keep them more secure....
  6. Sideways
    Sideways New Member
    May 12, 2009
    539
    37
    Above the Border^^^
    I am thinking of going to Carbon Fiber Glass...I hear this not only reduces weight but also decreases the drivers need to squint on sunny days.
  7. Ernesto
    Ernesto Club Coordinator
    May 16, 2009
    685
    733
    Oracle DBA
    Skokie Ill
    Carbon fiber wheel weights are much lighter than metal.
    Because it is rotating mass, a few ounces saved can translate to several pounds per corner at speed. You will definitely feel the difference
  8. Minidave
    Yes, your tires will shake! :D
  9. Angib
  10. cct1
    One of the sets of my track rims has a second valve for Nitrogen installation. Never done it though, you wind up changing pressures so much you'd almost have to have a tank with you. Now if it was Nitrous Oxide, that I might consider....
  11. moreorless
    moreorless New Member
    Aug 17, 2009
    343
    14
    In a pile of sawdust.
    I recently went with a carbon fiber antenna for the weight savings. See, the C/F antenna doesn't really work which means you don't need the radio and never did use the cd changer. So that all got removed. As well as the speakers and those now non-functioning buttons on the MFSW.
    Seat of the pants dyno revealed some impressive numbers. (Well...it was either those mods or the stop we made at Taco Bell.....)
    Anyways......two thumbs up.......
  12. Ernesto
    May 16, 2009
    685
    733
    Oracle DBA
    Skokie Ill
    I am experimenting with larger wheels to improve my top end speeds with my regular Cooper.
    I now top out in the mid 160's on long straightaways, but my acceleration is lacking..
  13. lotsie
    Right here
    By the looks of it the dealer could never tell, as the wheel gap looks OEM:Thumbsup:
    Mark
  14. Sideways
    Sideways New Member
    May 12, 2009
    539
    37
    Above the Border^^^
    What you dont see in this picture is the giant "Monte Python" hand just outside of camera range that pulled the MINI back and let it go!:cornut:
  15. lotsie
    Right here
    That's better than the big foot about to stomp on it:lol:
    Mark
  16. Herleman
    Herleman New Member
    May 25, 2010
    51
    42
    I always used new, filtered synthetic air. I have always found that if the tires are inflated slowly so as to not excite the newly created molecules the tires run much more smoothly, especially when backing.
    Its always been my practice to use Neosporin to lubricate the bead of the tire when I'm (ahem) mounting them. I also sterilize the TPMS sensors before I tighten their little locknuts. The valve cores have these little rubber covers that I put over them before I insert them into the ... well, you know...
    And I had to resurrect this thread.
  17. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    I use canned air normally used for cleaning computer equipment. Canned air is sterile and rubber safe. I custom CNC'd an adapter to use on most all the cans on the market. It generally takes about 2 cans per lb.
    I recommend changing out the tires air about every season.
    :rolleyes5: :lol:
  18. Sideways
    Sideways New Member
    May 12, 2009
    539
    37
    Above the Border^^^
    Remember to use Winter Air for winter driving and Summer air for summer driving...it was mentioned earlier...but honestly, who reads the WHOLE thread???
  19. minimark
    True but it can be altitude dependent, sometimes it is advantageous to use summer air in the winter... ;)
  20. lotsie
    Right here
    To lessen our carbon footprint, I empty the tire air into a tank, add some Glade air freshener, and refill the tires:Thumbsup: I sometimes even swap front tire air to rear tire air to reduce having to rotate the tires so much:idea:
    Mark
